How do I know which engine I have? - Page 2 - NewBeetle.org Forums
  #21 (permalink)
Old 05-18-2008, 01:28 PM
Mazzzja's Avatar
Foreign Exchange Orger
Zwanenburg, Netherlands
Car: 2001 Batik Blue ~ 2.0l, Bugje
Very interesting.
I will see what kind of engine code I have on Bugje.
But what I am wondering is, why does a person need to know the engine code?
  #22 (permalink)
Old 05-18-2008, 04:34 PM
miffmole's Avatar
NBC Driver
SC, USA
Default Car Data
Originally Posted by FineExampl
That's an interesting read Monica. Did you see anything about the other engine codes? AEG, AZG, etc.? I always forget what engine i have. Still, it's written at all those spots around the car so it's not hard to figure out.
At my local dealership I asked them to key in my VIN number in their computer and give me the readout...It tells just about everything.
To wit:
2004 Volkswagen
New Beetle GLS 1.8T Convertible
Sales Type
1Y75N4
Model Year
2004
Model
BEC
Model Designation
New Beetle Cabriolet
Engine Code
AWV (1.8 Turbo)
Transmission Code
EGX (5-Speed manual)
Finaldrive Ident
5S
Interior trim code
LJ
Roof Color
SL (Black)
Exterior Color
8E (Reflex Silver)
A8X US comfort equipment
AZO vehicle with standard production scope
BOD component parts set, complying with vehicle type for USA (without California), various parts
B34 legal requirements USA
COO operating permit, initial registration
CIF alloy wheels 6 1/2J x 16 offset 42
EOA no special edition
FOA no special purpose vehicle, standard equipment
FZO standard N.N.N.
GOC 5-speed manual transmission
G49 front shock absorption
H4B All-weather tires 205/55 R16 H (NAR)
JIL battery 280 A (60 Ah)
K8K convertible
LOL left-hand drive vehicle
L50 Suspension range 50 installation control only, no requirement forecast
MG8 4-cyl. gasoline engine 1.8 L/110 kW20V turbo, EU 4/D4/LEV base engine is T8C/T63
NIK leatherette seat covering (spiked) New Beetle sew pattern
Q1B standard front seats (NAR)
QGO without service interval prolongation
QSO without electronic map cooling system
QZ3 power steering (limited steering lift mechanism)
SOT pre-production series/SOP next MY
T8C 4-cylinder gasoline engine 1.8 L unit 06A.C
UON instrument insert with mph speedometer, tachometer, trip odometer
UB1 rear shock absorption for sports design
VOG MICHELIN tires
VUO without fender house liner
OA1 two doors
OAE front stabilizer
OBC rear stabilizer
OEJ installation differentiation for transmission MQ 250 vehicle components
OF2 fuel system for carburetor gasoline engine
OFA standard manufacturing sequence
OG4 cable gearshift
OGM emissions concept LEV 1
OHB vehicle class differentiation 1YO
OKA without stickers and badges
OL2 electric throttle actuation
ON3 standard rear axle w/ additional offset
OPD nameplate set "TURBO"
ORB ignition/starter switch locking system
OSC labels/plates in English
OTD front and rear floor mats
OVM information kit in American English
OYZ without determination of weight category for rear axle
1AT electronic stabilization program (ESP)
1C2 antifreeze up to -35 degree Celsius tolerance up to -40 degree C
1DO Without trailer hitch
1E4 activated charcoal canister ace. to ORVR and siphoning device for filling up
1EB without identification plate
1G2 steel spare wheel with original equipment tires
1HO without proportioning valve
1KV disc brakes, rear (Geomet D)
IMF comfort steering wheel for airbag system
1NL covers for alloy wheels
1PC wheel bolts with anti-theft protection (unlockable)
1QO without mass damper for steering wheel
1S1 tool kit and jack
ISA without additional engine guard
1T2 warning triangle
1WB transmission shaft w/ 100mm in diameter
1X0 front wheel drive
1Z2 increase in initial standard fuel filling
1ZD disc brakes, front (Geomet D)
2B1 additional exterior noise suppression
2C5 axial and vertical adjustable steering column
2D1 complete cd enhancing underbody panel
2G7 filler neck module 1 with insert
2JG body-colored bumpers
2LF fuel tank with special material treatment (coextrusion) with changed protective layer
2UA Standard design
2V5 fresh air intake system with activated charcoal canister
2W2 fuel filler cap, attached (NAR)
2WA without additional tires
3BO Without additional child seat anchor
3CO without center rear seat belts
3FT convertible top/folding top, powered
3H9 backrest release for front seats with "Easy Entry"
3K1 safety headrest system
3L3 manual height adjustment for front seats
3LR foamed film door and side panel trim over the full surface
3MH Dilours floor covering w/o scuff guard
3ND rear seat bench/backrest, unfolding
3PO without bracket for first aid kit and warning triangle
3QO without rear headrests
3UO without luggage compartment cover
3X2 load-through provision
3ZM 3-point seat belts, outer rear
4A3 seat heater for front seats separately controlled
4E2 tailgate/trunk lid release from inside (electrically)
4GF Windshield, heat-insulating glass
4KO radio remote controlled central locking operated from inside
4KC side and rear windows tinted
4L2 dipping breakaway inside rear view mirror
4PO rear floor panel module, type 1
4Q1 flame retardant materials
4R4 power windows with comfort operation and circuit breaker
4SQ left vanity mirror illuminated with cover and special mirror imprint (NAR)
4TQ right vanity mirror illuminated with cover and special mirror imprint (NAR)
4U5 luggage pockets on backrest
4UB airbag for NAR 4X8 side airbag front with head airbag and optimized head impact elements (USA)
5C1 body measures for increased safety requirements
5D2 carrier frequency 315 MHz
5JO without rear spoiler
5K5 Transit coating film with additional transport protection measures
5NO without grab handles at roof frame
5RR outer right rear view mirror: convex, US
5SH outer left rear view mirror: flat (USA)
5ZH headrests for front seats, articulated and height-adjustable with integrated release function
6AO without fire extinguisher
6E3 center armrest front
6FE body-colored outer rear view mirror housings and tailgate grab strip
6P2 license plate bracket, rear (NAR)
6PA plastic hand brake lever handle
6Q1 plastic gearshift knob/handle
6R1 leatherette gearshift boot
6SC tufted trunk floor covering
6W3 license plate bracket front (small, NAR)
6XN outer rear view mirrors: powered, separately heated
6YO without cruise control warning system
7A9 CD changer preparation (front) TAG electronic alarm system with vehicle immobilization device (for USA)
7B2 12-volt socket in luggage boot
7EO w/o heat accumulator/auxiliary heating
7LO without inertia benefit system/deceleration fuel cut-off/idle stop valve
7PO without lumbar support in front and rear seats
7PD platform group class 4
7QO without navigation device
7R7 side marker lights plus additional turn signal lights in outer rear view mirror
7S1 wind blocker
7X0 without park distance control
8BO without parking light mode
8E2 local interference suppression for FM/AM radio reception
SEA headlight with gas discharge lamp for driving on the right (US design)
8GL alternator 120A
8K4 Daytime running lights mode NAR SKA w/o catalytic converter warning light
8MO w/o rear window wiper and washer system
8N4 windshield wiper intermittent control with potentiometer (four speeds)
8Q2 Automatic headlight-range adjustment, static
8QE key for locking system with remote control
8R1 center high-mounted stop light
8SO without reading light
8SA taillight assemblies, standard design
8T2 cruise control system (CCS) electronic
8TA without rear fog light
8WO without washer fluid level indicator
8WD integrated front fog light
8X1 headlight washer system
8YT radio "Premium"
8Z6 Hot country
9AB manually controlled air conditioning
9DO without preparation for two-way radio installation
9FA without automatic transmission indicator light
9JA non-smoking version
9P7 seat belt warning light and acoustic, electric contact in buckle
9QO without multi-function indicator/on-board computer
9T1 heated washer nozzles, front
9TB additional warning lights (door area)
9U1 brake pad wear indicator
9VG sound system "Monsoon"
9WO w/o car phone preparation/installation
9Y1 Outside temperature display
  #23 (permalink)
Old 05-18-2008, 10:01 PM
05yellowbeetle's Avatar
Middlesex, NC,
Car: Herbie '05 Yellow 2.0 GL
I needed the engine code on my '98 to get the AC compressor, then they had to actually look at the compressor, apparently there were 3 different compressors that year.
  #24 (permalink)
Old 05-19-2008, 06:18 PM
Mazzzja's Avatar
Found my engine code on a sticker in the car manual: AQY
Engine designation? mel72349 1.9 Liter TDI 4 09-02-2006 04:26 AM
Engine Light? detailstation Questions, Issues, Concerns, or Problems with the New Beetle 5 08-04-2006 06:14 PM
Best engine cleaner IgottaBug! New Beetle Detailing/Cleaning 10 07-07-2006 04:44 AM
Engine cuts out inoverdrive 2.0 Liter Gas 2 04-05-2006 06:38 PM
Engine additives... iScott Miscellaneous Hoo-Ha Archive 8 03-16-2006 10:39 AM
