How do I know which engine I have? - NewBeetle.org Forums
Old 03-28-2007, 06:20 AM
jetadriano's Avatar
Quezon City, Philippines
Car: 2000 NB Euro Version
Default How do I know which engine I have?
How do I know if my 2.0 engine is AZG, AVH, AEG or whatever? Thanks.
Old 03-28-2007, 08:02 AM
branvan's Avatar
BadAss
Chicago, IL, USA
Car: 2001 GLS Silver Arrow
If you lift up the carpet in your trunk, there is a label under there that gives all the info on the car, including the engine code.
Old 03-28-2007, 02:19 PM
Breez's Avatar
Life is good.
Phoenix, Arizona, USA
Car: "BB" a 2001.5 New Beetle 2.0L GLS in Techno Blue
I remember that my label was missing on my beetle, so I checked my carfax... nodda. So I ended up just asking the dealership. Then I wrote it on a post it note and can't find it... guess Ill have to ask the dealership again LOL
Old 03-28-2007, 02:32 PM
vdubbugman53's Avatar
Arvada, CO, USA
what year is the car? if it is 98-01 you are AEG after that i believe it is AZG. you can tell for sure if you have AEG if your throttle body is drive by cable
Old 03-28-2007, 02:33 PM
Breez's Avatar
Life is good.
Yeah, Im a 2001.5 and Im pretty sure I remember writing down AZG
Old 03-28-2007, 05:51 PM
manoverboard987's Avatar
Lurker Status Assumed.
Car: 2000 Jetta GLS 2.0L
There's only one way to be sure. Rip off your engine cover, and you'll see a sticker on a plastic cover just to the left of your intake manifold...
almost there...
a little closer...
BAM!
Old 03-29-2007, 03:54 AM
Breez's Avatar
Life is good.
I love the PAY ATTENTION TO THE MOTOR!!!
Old 03-29-2007, 04:24 AM
Yup. That's the funny German way of saying THIS ONE RUNS ON GAS AND NOT DIESEL!!!
Old 03-29-2007, 02:11 PM
Breez's Avatar
Life is good.
Hahaha, last time I was with my friend who had a TDI golf, I went into the gas station and got a soda. I told the clerk (who was a young kid) I think that women is putting diesel in her car! The kid almost stopped the pumps, he got on the intercom and started yelling at her to stop!
When I got back out to the car I almost pee'd my pants laughing... she was just a little ticked at me. But it was soooooo funny. Thats the only time Ive done that. I promise!!!
Old 04-10-2007, 06:22 AM
jetadriano's Avatar
Default Engine Designation
Okay my engine number starts with "AQY". It's a 2000 model beetle European edition.
almost there...
a little closer...
BAM!
Old 06-09-2007, 08:14 PM
Question two headed monster
My Girlfriend must have a 01.5 because the trunk says AVH and the motor says AZG
Old 06-10-2007, 02:16 AM
Lnzbug's Avatar
MINI & NB FOR LIFE!
Arlington Heights, IL, USA
Bree I just saw this, you are bad!! That was a good one
Old 05-07-2008, 07:21 PM
antonym's Avatar
¯\_(ツ)_/¯ (o\_l_/o)
Car: 2013 Kia Rio-5
Yeah! How do I tell what is what? I think this is the same thing that I see. What are the diferences between all these engines?
Old 05-07-2008, 07:31 PM
mojo_trixie's Avatar
Fayetteville, AR, USA
Car: 2000 Reflex Yellow GLX 1.8T
Here is a lil info I found on the Vortex: Vortex Engine Code
Volkswagen Engine Info
Engine Code: AWD
Model Years: 2000 (11/99 on)
Compression Ratio: 9.5:1
Horsepower (SAE Net): 150hp @ 5700RPM
Torque: 155ft. lbs.@ 1750RPM
ECU: Motronic ME7.5
DP Size: 55mm (2.17")
Turbo: K03
OE Boost: .6 Bar (8.7psi)
Engine Code: APH
Model Years: 2000
Horsepower (SAE Net): 150hp @ 5500RPM
Torque: 155ft. lbs.@ 1950RPM
ECU: Motronic ME7.5
DP Size: 50mm (1.97")
Turbo: K03
Engine Code: AWW/AWV
Model Years: 2001 (07/00 on)
Compression Ratio: 9.3:1
Torque: 162ft. lbs.@ 1950RPM
ECU: Motronic ME 7.5
Turbo: K03s
Engine Code: AWP
Model Years: 2002+ (06/01 on)
Horsepower (SAE Net): 180hp @ 5500RPM
Torque: 174ft. lbs.@ 1950RPM
ECU: Motronic ME7.5
Turbo: K03s
OE Boost: .8 Bar (11.6psi)
2nd O2 sensor on AWD can be tapped for A/F gauge
AWP engines lack Fuse 6
AWD had slightly different fitting coilpacks, they use clips and allen keys to be secured.
The AEB engine code(non-dbw) has the largest intake ports and consequently is one of the most in demand head's to put on our cars.
APH engines have a "baby" K03 turbo--not same as Golf and TT
APH engines have the 2L exhaust
APH engines have a smaller Intercooler (even smaller than Golf part). Less air through turbo = less boost.
APH engines have Small Injectors, and 3 bar Fuel Pressure Regulator (sufficient for 150HP that’s it; maybe 160 max.)
Trixie
Old 05-07-2008, 07:48 PM
FineExampl's Avatar
Poopship Destroyer
Edison, Dirty Jersey, USA
Engine Code: AWD
ECU: Motronic ME7.5
Turbo: K03
Engine Code: APH
Model Years: 2000
ECU: Motronic ME7.5
Turbo: K03
Turbo: K03s
Engine Code: AWP
ECU: Motronic ME7.5
Turbo: K03s
That's an interesting read Monica. Did you see anything about the other engine codes? AEG, AZG, etc.? I always forget what engine i have. Still, it's written at all those spots around the car so it's not hard to figure out.
Old 05-07-2008, 08:12 PM
Hehe when I posted I didn't notice that I was in the 2.0 thread so all those above won't include you guys.
The AEG is the only engine in the 2.0 lineup that still has the throttle-by-cable system. All later engines use the Drive-By-Wire system. Thus, EPC is not available for the AEG engine code
Old 05-07-2008, 08:18 PM
Picknicker's Avatar
Germany
Car: '99 2.0i
Om - why rip off the engine cover? Just have a look in your handbook / service book - the engine and transmission code is noted there (I think on the first few pages somewhere)... This might not be the correct code if the engine was exchanged once... If it wasn't - it's the right one.
Old 05-07-2008, 08:21 PM
They may not have the handbook or service book. I know what mine is because I saw it stamped on the engine and NOT under the engine cover. So there are several ways to find it. Now they have the option on how they want or are able to find it.
Old 05-07-2008, 08:26 PM
Picknicker's Avatar
Germany
Car: '99 2.0i
That's a point
You know more than I do - I am from Germany^^ Bad thing is - also diesel engines got this nice sentence on 'em
But in fact - there are a lot of people who got a big sticker saying "DIESEL ONLY" on their tank cover^^
Old 05-17-2008, 10:53 AM
antonym's Avatar
¯\_(ツ)_/¯ (o\_l_/o)
Car: 2013 Kia Rio-5
OK.
So an AZG is simply a Low Emmisions version of a Super Ultra-Low Emmisions AVH with 1 more Knock and 1 more O2 sensor.
That clears things up a bit for me. Thanx!
Engine designation? mel72349 1.9 Liter TDI 4 09-02-2006 04:26 AM
Engine Light? detailstation Questions, Issues, Concerns, or Problems with the New Beetle 5 08-04-2006 06:14 PM
Best engine cleaner IgottaBug! New Beetle Detailing/Cleaning 10 07-07-2006 04:44 AM
Engine cuts out inoverdrive 2.0 Liter Gas 2 04-05-2006 06:38 PM
Engine additives... iScott Miscellaneous Hoo-Ha Archive 8 03-16-2006 10:39 AM
