Even if I replace the MAF sensor, is that gonna stop the hesitation?
My buddy thinks it's the coil pack. I have been leaning more so towards the MAF sensor. I just don't know if tha MAF sensor will cure the hesitation /lack of power problem. ![]() |
I had your problem and here is what I did. Changed the spark plugs, wires, fuel fliter and lastly the coil. I bought the coil from E-Bay for $40. Also, I stop using regular gas(87) and switched to 89. So far, running excellent. Also, I cleaned the throttle body with throttle body cleaner and the MAF with MAF cleaner. That also seemed to help a great deal. My car runs 100% better than when I bought it. Good luck. Also, just in case you want to get your injectors cleaned, I sent my Fieros injectors to www.cruzinperformance.com. The guy, Rich, does a hell of a job getting them to flow back up to spec. I believe the proce is about $14 per injector. A very reasonable price to pay.
I think you have a MAF going out. If it were the coil you should get misfires and codes would be logged. Either randon misfires or specific cylinder misfires. The bad MAF gives more general codes and hesitation or poor drivability.
Usually (with mine anyway) idles fine but has problems at certain RPMs. |
Still no luck. I replaced the Coil pack and I cleaned the MAF. The car is still lacking power. Idles fine but when I give it gas it stutters and hesitates. I'm getting real frustrated because I have already put like $600.00 into this thing over the last week and half.
The codes I was getting were: long term fuel trim too lean, system too rich, random/multiple cylinder misfire, cylinder 1 misfire, cylinder 2 misfire, O2 Sensor (pre-converter) heater malfuction, O2 Sensor (pre-converter) no activity, and MAF Sensor low input. Help, before I push the thing off a cliff! ![]() |
Well, I finally gave up and took it to a friend of a friend whom specializes in VW's, Beemers and Mercedes. He runs a little shop out of his house.
He looked it over and he thinks it's an intake manifold leak. He said I did the right stuff (thanks to the vast cornicopia of knowledge here at the org) and he said it shouldn't be too terrible to fix. ![]() |
Coolant temp. sensor and vacuum hoses. Both are cheap and easy to replace.
Good luck!!!
Kirk & Pam & "Key Lime" "BUGSTUFF" - Unique New Beetle Accessories Northeast IL VW Association Volkswagen Club of America "Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways - Crown Royal in one hand - Cigar in the other - body thoroughly used up, totally worn out and screaming "WOO HOO, What a Kick Ass Ride!" |
| Need Cam suggestions | HaloUmpaLumpa | Technical Modifications | 6 | 05-15-2007 05:30 PM |
| Suggestions | thricey | Miscellaneous Hoo-Ha Archive | 19 | 04-16-2007 01:38 PM |
| Need new struts! Any suggestions? | jsw5620 | Technical Modifications | 3 | 08-25-2006 02:40 AM |
| Your suggestions are requested | iScott | Miscellaneous Hoo-Ha Archive | 19 | 06-19-2006 08:06 AM |
| Need Wheel Suggestions | dgoldbe2 | Styling Modifications | 11 | 09-25-2005 04:29 AM |
