Fan Issues???? Should I be concerned - NewBeetle.org Forums
Old 05-21-2007, 02:40 PM
heatherm's Avatar
Default Fan Issues???? Should I be concerned
I have kind of a werid situation because it only happened once but I want to make sure it doesnt happen again and cause harm to my bug.
On Saturday I drove it about an hour and shut it off then a few min later my boyfriend moved it and when he turned it off the fan was still running very loud as if the car was running, im like turn the car off and hes like it is. So I turned it back on and then shut it off and then it was quiet. This only happened once but is that normal ....it was around 85 out was it just wanting to cool it down more or what? Any suggestions would be great.
Old 05-21-2007, 02:44 PM
kellyshair's Avatar
In My Experience Thats Normal In Alot Of Cars
Old 05-21-2007, 03:18 PM
Porkchop's Avatar
a.k.a. porkchopzz4
Cartersville, GA, USA
Car: '00 Silver GLS 2.0L auto
There is a thermoswitch in the radiator that keeps the fan running until the temperature of the coolant falls below a set point. On a hot day, El Buggo's fan will run for between 30 secs to 2 minutes after the engine is off.
"The rich ruleth over the poor, and the borrower is servant to the lender."
Proverbs 22:7
Old 05-21-2007, 06:44 PM
gilligan's Avatar
MI, USA
I agree, it is not only normal to do that but its a much better concept than older cars that just let it boil until it cooled off enough.
Issues in my '99.. pinktimbs Transmission Talk 1 05-18-2007 03:23 PM
should I be concerned? arbowman Questions, Issues, Concerns, or Problems with the New Beetle 9 04-11-2007 11:33 PM
Tire Issue: Should I be concerned? pinktimbs Questions, Issues, Concerns, or Problems with the New Beetle 17 11-30-2006 11:40 PM
1.8t issues exzotikbeetle 1.8 Liter Turbo 3 06-22-2006 02:19 AM
Fan on fan off prudence Questions, Issues, Concerns, or Problems with the New Beetle 0 10-09-2005 11:15 PM
