Oil Change - NewBeetle.org Forums
Old 06-01-2007, 03:07 PM
Default Oil Change
I bought my daughter a 2000 VW beetle with the 2.0 liter gas engine. It is time for an oil change, filter, air filter and plugs. Can you give me recommendations for this car?
Thank You
Old 06-01-2007, 03:24 PM
LadybugEwa's Avatar
PUNCHED BUG
Toronto, Ontario, Canada
oil: 5W40 (I use Castrol Syntec)
plugs: when you do the plugs, it's best to do the wires too
cabin air filter: is under the dash on the passenger side. You'll need a torx screwdriver, but first slide the panels out starting with the top central panel.
you might want to do the fuel filter while you're at it - it's located by the rear passenger tire. Good luck, and welcome
Here's a look at Ladybug
Old 06-01-2007, 03:28 PM
noR's Avatar
Administrator
Jackson, MS, USA
sure: Synthetic 5w30 oil, k&n drop in air filter, and Bosch plugs, get a plug wire tool, and new plugs. I'm not sure what gap is needed for the 2.0 plugs; and don't have any suggestions in regards to the wire brand.
noR | me | Phrog
PHROG
Old 06-01-2007, 03:44 PM
Thanks all, Looks like I'm off to the auto parts store.
Old 06-01-2007, 05:09 PM
Interesting... some parts a very difficult to get. Couldn't even order plug wires, had to order the cabin air filter and they only had one option for the plugs.
Anyone else experiance this? Where do you get your parts for your car?
Thanks
Old 06-01-2007, 06:18 PM
noR's Avatar
Administrator
Jackson, MS, USA
what? um, autozone; or the internet usually.
What do you mean they can't even order plug wires? Do you really have a 2.0 motor? (the others don't use wires)
Old 06-01-2007, 06:23 PM
The motor is definitely a 2.0 liter fuel injected 4 cylinder and I went to Autozone for the parts and the guy showed me on the computer that he didn't even have an option to order the plug wires....
I even pulled the black cover off of it to see how difficult it would be to get to the plugs and there are wires there.
Old 06-01-2007, 06:28 PM
Kissimmee, FL, USA
Car: 1999 GLS
They do. I got my wire plugs from them with lifetime warranty. The have in their system for some unknown reason two different kind of 2.0L engines. Have the guys take a look at the engine and compare the wire plugs. When I purchased mine, the gentleman came out and took a look at the engine to compare wires. Good luck
Old 06-01-2007, 06:33 PM
Well I have to go back and get the cabin air filter anyway(had to order it) so I'll talk to them about it then.
Thanks
Old 06-02-2007, 12:10 PM
You have got to be kidding me.... air filter change is ridiculous.... oil filter probably has never been changed and who ever did it last I'd like to strangle, they must have seen how tight they could get it and plugs... please
But it's done, accept for the fuel filter and cabin air filter. Took me longer then expected so I'll tackle those today.
Old 06-02-2007, 07:52 PM
I know the dealer tightens the oil filters pretty tight. I had mine done there once (had a coupon for a free oil change). Then my bf went to change it the next time and he had a heck of a time getting it off.
I haven't done the fuel or air filter in my car since I got it (a little over 2 years ago...). Hopefully going to get to that this summer
Old 06-02-2007, 09:24 PM
LadybugEwa's Avatar
PUNCHED BUG
Be careful not to break the clips that hold the fuel filter, or you'll be getting a whole new brakeline...
Old 06-04-2007, 07:34 PM
well everything is done now accept the cabin filter, need to go pick it up today.
Another question, I bought the cable to read engine codes and I know I need some software to go with it. How do I know which sofware I need?
Thanks,
Oil leak after 1rst oil change. shafrs3 Questions, Issues, Concerns, or Problems with the New Beetle 13 04-09-2011 09:04 PM
Oil Change Exigen 2.0 Liter Gas 18 05-21-2007 01:30 AM
Oil Change Dan_Man The Canada Corner 2 07-04-2006 05:04 PM
Oil change ??'s bugdreamsdocometrue 2.0 Liter Gas 2 05-06-2006 08:27 AM
oil change Spud Bug 2.0 Liter Gas 12 11-10-2005 07:54 PM
