Driver side taillight out completely - NewBeetle.org Forums
Old 06-04-2007, 04:33 AM
Default Driver side taillight out completely
my daughter's bug has a crack on the taillight lens, and water got inside. The bulbs got flooded and shorted out. I check the fusebox on the driver side door, and all fuses are good. Is there another fusebox for taillight. The passenger side works fine.
Your suggestion would be appreciated.
Paul
Old 06-04-2007, 03:43 PM
vdubbugman53's Avatar
Arvada, CO, USA
light bulb?
Old 06-04-2007, 09:09 PM
Default Light bulbs
Originally Posted by vdubbugman53
light bulb?
I tested the circuit with a volt metter. There was no voltage at all. The old bulbs appear to be OK, but it still does not work when I put in new bulbs.
Thanks
Old 06-04-2007, 09:17 PM
Arvada, CO, USA
hum...may want to double check fuses and look under the fuse box on top of the battery...that is really all i can think of
Old 06-05-2007, 12:25 AM
Default Thanks!
I'll check it tonight. Appreciate your suggestion!
Paul
Old 06-08-2007, 01:27 AM
Default Fixed
I blew the connectors out with the pressure air can, and the lights work.
Thanks again!
Paul
Water on driver side floorboard funky 1.8 Liter Turbo 4 04-10-2012 03:46 PM
'05 NB Driver Side Window Problem FLSHADOW74 Questions, Issues, Concerns, or Problems with the New Beetle 0 02-03-2007 03:23 AM
Driver Side Power window Switch cbenton1961 2.0 Liter Gas 3 12-19-2006 08:34 PM
WTB driver side headlight.... mark Market Place Archives 2 08-07-2006 05:14 PM
Driver Side Seat Airbag dgrant09 2.0 Liter Gas 9 04-17-2006 08:09 PM
