motor shaking in the morning - NewBeetle.org Forums
Old 06-05-2007, 12:30 PM
denisse's Avatar
Default motor shaking in the morning
Hi, It is me again. It happens for a while that during the morning when I warm up the car and when I amn in a stop sign the car shake a little.
THis mornign I warm up the car completly I move it backward and start tremblimg a lot. I move it upwards and stop....
For the last few days we are having this rain, humid days.
Thanks Please help me with this one too.
Old 06-05-2007, 12:31 PM
denisse's Avatar
Old 06-06-2007, 02:19 AM
Kitchen's Avatar
Stud
Houghton Lake, MI, USA
Car: "Midnight" 98 New Beetle
i had the same problem and now it is worse. i am at the point where i have to put my car in neutral at a stop sign cause i think my car will stall cause it shakes so bad. i took it to advance auto parts to have them hook their meter to it and they say i need new plugs and wires. Not sure if this helps you, i'm still waiting to fix mine cause i'm waiting for a second opinion.
Old 06-06-2007, 02:53 AM
iScott's Avatar
Die with your boots on
Atlanta, GA, USA
Car: Noir'a, black '98 2.0
I have the same problem when she's cold. But I've been trying to solve it for quite some time with no solid results. In y'alls, you're probably having a simple misfire and you should change your plugs and wires. Could also be the coil pack. Maybe a motor mount. But I'd def start with plugs. Good luck.
Floored
Old 06-06-2007, 02:55 AM
Kitchen's Avatar
Stud
i have the printout from AAP do you know anything about the codes?
Old 06-06-2007, 03:20 AM
iScott's Avatar
Atlanta, GA, USA
There is a code guide somewhere around here. Go ahead and post them up.
Old 06-06-2007, 04:09 AM
Kitchen's Avatar
Stud
Vehicle Scanned
Global OBDII
Vehicle
DTC (Codes)
P0140
02 Sensor
CKT No Activity
(Bank 1 Sensor 2)
P0141
02 Sensor Heater
Circuit Malfunction
(Bank 1 Sensor 2)
P1300
Manfacurer Contrl.
Ignition System or Misfire
P0300
Random/Multiple
Cylinder
Misfire Detected
P0303
Cylinder 3
Misfire Detected
P0302
Cylinder 2
Misfire Detected
DTC Pending(Codes)
P1300
MAnfacurer Contrl.
P0301
Cylinder 1
Misfire Detected
Old 06-06-2007, 12:17 PM
Kissimmee, FL, USA
Car: 1999 GLS
Originally Posted by Kitchen
Vehicle Scanned
Global OBDII
Vehicle
DTC (Codes)
P0140
02 Sensor
CKT No Activity
(Bank 1 Sensor 2)
P0141
02 Sensor Heater
Circuit Malfunction
(Bank 1 Sensor 2)
P1300
Manfacurer Contrl.
P0300
Random/Multiple
Cylinder
Misfire Detected
P0303
Cylinder 3
Misfire Detected
P0302
Cylinder 2
Misfire Detected
DTC Pending(Codes)
P1300
MAnfacurer Contrl.
P0301
Cylinder 1
Misfire Detected
When was the last time you changed you plugs and wires? It sounds to me like you may be in for a tune up. I replaced the coil, plugs and wires. Then, I cleaned the MAF and TB and no more problems or codes. Good luck!
Old 06-06-2007, 01:48 PM
denisse's Avatar
I have the PO303 and PO172. My husband told me that we need to change the plug and wires. Probably they never were changed. Imagine that when I checked the air filter, It was the original (wsame with fuel filter) and it is a 99.
I will check the wires and spark plugs.
denisse's Avatar
Somebody have a picture of have to do it????
Old 06-06-2007, 02:51 PM
Kitchen's Avatar
Stud
don;t they have to lift the engine up to put in the spark plugs?? i heard its not something i can do myself like most cars.... and what is a TB?
Old 06-06-2007, 04:11 PM
gilligan's Avatar
MI, USA
TB is throttle body and yes it has to come off to change the spark plugs although some will tell you it doesn't have to. I see no other way to do it.
No you dont have to lift the motor to change plugs just the water pump.
Old 06-06-2007, 04:25 PM
iScott's Avatar
Atlanta, GA, USA
I've changed the plugs numberous times without taking anything off. The throttle body isn't even close to the plugs. We are talking about the 2.0, right? Just get a long ratched extension and you'll be fine.
Old 06-06-2007, 11:40 PM
Jdmbeetleon18z's Avatar
DrewSkiii
Waipahu, HI, USA
Car: 99 beetle sittin low on 18z
or to make it easier.. go get an allen wrench and take off the top intake manifold and it be easier than a butter.. just my two cent opinion.. definetly u will need a tune up, coil, spark plug n wires.. might want to check your fuel filter too and belts since your there for a tune up... no need to lift your engine and go underneath.. becuase your coil is below the sai pump, the spark plug is under the intake manifold and u should be set up.. goodlcuk.. Shoots
Old 06-07-2007, 03:23 AM
Kitchen's Avatar
Stud
thanks for the tips guys.
I went to AAP today and bought The Haynes Repair Manual for my car and it looks like it will be a lot of help in letting me fix my car instead of the car repair places charging me an arm and a leg.
Going to try and clean the MAF by myself tommorow.
Old 06-07-2007, 03:47 AM
iScott's Avatar
Atlanta, GA, USA
Sweet. The manuals def help a lot. Cleaning the MAF is really easy. CDC makes a special MAF cleaner that you just spray on there. Just be real careful with the MAF; sorta delicate and way overpriced. If it is dirty, it'll help with idle and stuff. Good luck!
Intermittent weird shaking and metal noise coming from timing belt flip240 Technical Modifications 6 11-12-2006 02:00 PM
steering wheel shaking QuanBlackBug Questions, Issues, Concerns, or Problems with the New Beetle 2 06-12-2006 01:01 PM
Morning thumper New Member Forum 13 02-22-2006 03:54 PM
CEL plus violent shaking at idle Katiebug Questions, Issues, Concerns, or Problems with the New Beetle 16 02-14-2006 06:04 PM
Going to Dalton,Ga. in the morning Buglover Miscellaneous Hoo-Ha Archive 3 02-11-2006 09:04 PM
