OEM Code P1582 - NewBeetle.org Forums
Old 06-05-2007, 07:43 PM
Lampasas, TX,
Car: 2000 GL
Default OEM Code P1582
My daughters 2000 Beetle has had the check engine light staying on for a few days and then going off for a few days. It has been doing this for about 3 weeks now. It seems to be running fine. I took the car to AutoZone today and they plugged the computer to it and got the code P1582. It gives three possible problems.
Idle Adapation At limit
Electronic Throttle monitor data available
Cruise control Module direction low input.
Any thoughts on what any of these means and how serious it is. Is it alright to drive or take it straight to the dealer.
Old 06-06-2007, 06:39 AM
180 Degrees out of faze
Central Coast, CA,
Car: 98 TDI NB.
The correct code is:
17990 P1582
Idle Adaptation at Limit
Usually means the throttle body has a problem. Try using some throttle body cleaner (not carb cleaner) to get the gunk out.
P0171 + P1582 / DBW question branvan 2.0 Liter Gas 9 04-08-2010 06:16 PM
P1582 smellofnitro 2.0 Liter Gas 3 05-01-2007 02:09 PM
Don't trust the man - P1582 code gabluebug 2.0 Liter Gas 3 04-01-2007 12:27 AM
Got Code: P1582, What to do next? BigRedOne98 2.0 Liter Gas 1 03-18-2007 02:12 AM
OBD-2 code: P1582 "Powertrain" Dan Campese Transmission Talk 2 02-24-2006 08:06 AM
