What is this? - NewBeetle.org Forums
Old 06-05-2007, 08:35 PM
Noviisi's Avatar
Kupla Man
Finland
Car: New Beetle 2.0 1999, VW Beetle 1971
Default What is this?
Hi!
What is this part and what does it do?`
Mine looked a bit wet today, maybe oil?
Could this be leak? Should I be worried?
Old 06-05-2007, 08:42 PM
gilligan's Avatar
MI, USA
Thats your power steering resevoir I believe.
And I've never seen a dry one.
Old 06-05-2007, 11:33 PM
Atomic_Knight's Avatar
Autobots! Roll out!
Camas, WA, USA
Car: 2001 New Beetle GL 2.0 ltr
I guess the next logical step is to see if your steering has been affected. Is it hard to turn, or is it the same as always? If not affected, and the your fluid level is fine, it just might be some condesation or a very minor seal leak.
Old 06-06-2007, 12:19 AM
digitalputty's Avatar
Where is home ....
Lone Tree, Greeley, USA
Car: 2003.5 GLS BLCC (Zoomer)
Mine is like that too. Dealer told me it was a weak/broken clamp that causes that and they replaced it. 0_o It still 'leak' though.
J'veux pas mourir tout seule.
Old 06-06-2007, 11:44 PM
Jdmbeetleon18z's Avatar
DrewSkiii
Waipahu, HI, USA
Car: 99 beetle sittin low on 18z
its your powersteering fluid.. check the hose.. usually they dont check hoses.. there could be a slight small hole in the hose or if not see if the clamp is tiight.. just my input.. goodluck.. shoots
