it sounds like your alternator is not charging the battery. First, make sure all the connections to the battery are properly secured. Second, take a look at you alternator, make sure the connection are also secured. If everything is secured then I would have to assume that your alternator is probably bad.
I put the car on a charger for an hour, it then started, but the battery light was on. I tested voltage at battery while running and it was only 10.8 volts.
Assuming I need a new alternator, any suggestions on where and what type / brand to buy?? Thanks! |
call around to your local parts stores and check prices. Most alternators you find will be remaned units. Nothing wrong with using them and saving a few bucks. Make sure before you go up to buy one that you take your old one with you so that you wont be charged for the core. KEEP THE RECIEPT!!!! Just incase you have an issue with it before the warranty expires. To be on the safe side I would take the battery up there and have them test it also. It isnt un common for a battery to get fried from a bad alternator or vise versa.
u do not need specs of your alternator.. just the yr, model engine size.. and the info stuff they have do the rest and will pull up the right batter.. if im not mistaken its a mt 48 for interstate batt... alright take care.. shoots
thats true.. if not just call dealer.. get the right info .. more likely they will ask for your vin.. usually engine size, vin number, production date.. thats how i order my parts from all local parts store, checkers, napa,autozone.. never had problem by just givin the basic information.. thanks tho seca.. appreciate it.. shoots
i like to take challenges |
I am thinking I may buy a used unit from a salvage place on ebay and close to me, only $49 with a lifetime replacement guarantee? If it goes bad its only a 15 minute project to swap it out. Just run the risk of it failing while on the road I guess? |
You may want to replace the automatic belt tensioner if it is the original one, if the tensioner is weak, this could cause the new alternator to fail prematurely as well as destroy the new belt.
| HELP Generator light on but new alt and battery... | gsoltis29 | Questions, Issues, Concerns, or Problems with the New Beetle | 10 | 04-15-2007 11:17 AM |
| Problem after dead battery. Help!!! | nibeil | 2.0 Liter Gas | 17 | 11-27-2006 01:17 AM |
| 99 Battery going dead Please Help! | C.Hotchkiss | 2.0 Liter Gas | 1 | 10-29-2006 05:17 PM |
| Found why NB battery going dead | fatdaddy | Technical Modifications | 3 | 03-14-2006 10:47 AM |
| Dead battery or..? | quiong | Questions, Issues, Concerns, or Problems with the New Beetle | 3 | 12-11-2005 04:15 AM |
