Toe in check and alignment - NewBeetle.org Forums
Old 06-12-2007, 06:16 AM
Default Toe in check and alignment
anyone know how to check the toe in and toe out for NB ?
thanks
Old 06-12-2007, 02:21 PM
vdubbugman53's Avatar
Arvada, CO, USA
find the middle tread in your tires and measure the distance between them
Old 06-12-2007, 03:35 PM
how do you measure on the back side of the tires. I see the body's car is too low.
thanks
Old 06-12-2007, 10:11 PM
Nothing beats a real alignment machine. Try to find a shop that uses Hunter equipment. Some of the best equip. there is. Steer away from ones that use John Bean equipment. Like where I work lol
Old 06-12-2007, 10:27 PM
noR's Avatar
Administrator
Jackson, MS, USA
Too low to fit a tape measure by the tire?
Lay on the ground and try again.
But yeah, really the only way to properly align your ride is with an alignment machine.
A tape measure will do fine for a parking lot alignment though, well that'll give you a toe check anyway.
noR | me | Phrog
PHROG
Is there a howto for door alignment ? ninsei Questions, Issues, Concerns, or Problems with the New Beetle 2 04-18-2007 03:34 AM
hood alignment??? niceguyede Paint and Body 1 12-08-2006 01:41 PM
Help a Lady Dip Her Toe In... Kermie Paint and Body 10 11-03-2006 08:56 PM
Alignment advice needed Porkchop Questions, Issues, Concerns, or Problems with the New Beetle 3 01-06-2006 10:07 PM
Top alignment Deserion New Beetle Convertible 0 10-26-2005 07:38 AM
