99 2.0
My wife said the car was loosing power and shuttering. I felt it "once" other than that it ran fine. Then after a day I finally got a check engine light. After pulling the codes. MAF and misfire cyl 3 cyl 2. I changed the MAF and the air filter. Ran the car, it seemed ok. BUT then returned to a worse misfire situation, sometimes, or else it ran fine again!. Light came on again but No hard codes came up except "P0302 Cyl.2, P0303 Cyl.3, P0102 (Intake air circ. signal too low) I don't think this is anything. The wires and plugs are not very old and they visably in the dark they are not "Arcing" From what I read here it seems the the culprit is the COIL PACK. Does anybody have any opinions. ![]() |
- Joe ![]() 2001 Techno Blue Pearl 5 spd GLS. Heated leather, fog lights, power sunroof, alloy wheels. |
"The rich ruleth over the poor, and the borrower is servant to the lender." Proverbs 22:7
I just changed the spark plugs and wires with stockers and it was actually quite simple on the 2.0. Removing the secondary air pump was easy as well. I haven't notice if it's running any different yet (only has 40k on it) but I only drove it a mile os so afterwards.
And was it giving you the red temp light? |
Actually, nothing went wrong with the temp light. The tech said there was some miscommunication between the computer, the broken sensor, the engine, and that's why the misfire happened. Not sure of the exact details, but I have had zero CELs or problems since, and my car is running a million times smoother now. It had been shaking and such when I started it up in the morning because the engine wasn't getting the fuel it needed to warm up, because the engine thought it was hot already.
I'm no car expert but I trust what works, and what worked was changing out that sensor. |
| can anyone say misfire? | bugwugvw | 2.0 Liter Gas | 8 | 06-21-2007 01:17 AM |
| Misfire | vdubs | 2.0 Liter Gas | 2 | 04-17-2007 11:55 PM |
| Misfire Codes!!! | pcb122 | Questions, Issues, Concerns, or Problems with the New Beetle | 8 | 01-31-2007 02:17 AM |
| odd misfire with no codes | Holland | 1.8 Liter Turbo | 11 | 12-06-2006 05:08 AM |
| P0301 Cylinder 1 Misfire Detected | Bugged in CA | 2.0 Liter Gas | 5 | 12-16-2005 08:25 AM |
