2001 Beetle P1128 Error COde - NewBeetle.org Forums
Old 08-07-2007, 06:58 PM
Default 2001 Beetle P1128 Error COde
Hi, My Check Engine light came up and I was getting 2 error codes on my 2001 2.0 Beetle, One was code P0172 an the other was P1128. After I cleaned the MAF with the MAF cleaner, and the P0172 code went away, but I still getting the P1128 code, I was wondering should I get the replacement of the MAF or most likely the P1128 code is releated with the Vacumm hoses? Please advise.
Thanks
Alex
Old 08-08-2007, 12:49 AM
vdubbugman53's Avatar
Arvada, CO, USA
coolent temp sensor
p0411 error code vibelife 1.8 Liter Turbo 1 05-02-2007 01:42 AM
Pleeease Help! Error Code 0522 katy Questions, Issues, Concerns, or Problems with the New Beetle 1 01-27-2007 11:01 PM
dreaded p1128 code gator 2.0 Liter Gas 4 01-26-2007 12:42 PM
Error code P1128 PullMeUnder 2.0 Liter Gas 1 10-29-2006 12:47 AM
16795 error code on '00 1.8T lryangray 1.8 Liter Turbo 1 06-21-2006 04:51 PM
