Suspension squeak - NewBeetle.org Forums
Old 09-14-2007, 12:25 AM
seattle, WA,
Car: 2000 4 speed
Default Suspension squeak
After searching the forum for clues this morning, I checked out the front sway bar bushings,strut bushing, and tie rods for a bad squeak we get on hot days. It turned out to be the inner tie rod end on the right side. Having just replaced the same part on my Eurovan, I opted to poke a small hole in the boot and shoot the joint with white lithium grease and seal the hole.
The squeak is gone (for 5 minutes or 5 years...who knows) and it was an easy fix. Replacing the inner tie rod end entails a front end alignment and a nasty boot reinstallation, so I gambled this would work for some time. (2000 New Beetle)
Thanks for getting me started.
Old 09-14-2007, 01:09 PM
noR's Avatar
Administrator
Jackson, MS, USA
Right on, not a bad plan. Good luck and thanks for sharing.
Nice 1st post.
noR | me | Phrog
PHROG
suspension GENETIX RACING Styling Modifications 5 08-30-2011 05:46 AM
What's that squeak from my engine when I shift hard? spinjector 1.8 Liter Turbo 4 07-30-2007 05:33 AM
Smooth suspension Fixxser Technical Modifications 9 04-12-2006 09:14 PM
TS Suspension vs. 1.8T GatorBeetle 1.8 Liter Turbo 16 02-21-2006 03:53 PM
Seat Squeak Dave Questions, Issues, Concerns, or Problems with the New Beetle 5 01-08-2006 03:38 AM
