2.0 liter -code reads "throttle control motor lock fault" - NewBeetle.org Forums
Old 09-27-2007, 02:23 AM
Default 2.0 liter -code reads "throttle control motor lock fault"
Hi:
Can anyone help. We bought our daughter a 2001 VW New Beetle, less than a year after buying from another individual, the check engine light continues on and on. Newest code is: throttle control motor lock fault". We have already replaced the Mass air flow and oxygen sensors (plus the spark plugs, spark plug wires, battery and alternator). Any ideas on what to do? Also, daughter honked the horn and her "AIR BAG" indicator light came on. Anyone know what that problem could be? Thanks so much for any help.
222 mpg "1-Liter Car" concept Darkstar Miscellaneous Hoo-Ha Archive 9 04-19-2007 07:38 PM
"How To" fix (lube) that sticky door lock. Fowvay Technical How-To 0 11-26-2006 05:06 AM
Throttle Body "cleaning" ????? dipwaded 2.0 Liter Gas 2 07-08-2006 02:51 PM
OBD-2 code: P1582 "Powertrain" Dan Campese Transmission Talk 2 02-24-2006 08:06 AM
