Temp light warning - but coolant looks ok? - NewBeetle.org Forums
Old 10-11-2007, 01:45 AM
Default Temp light warning - but coolant looks ok?
Hello.
My temp light was flashing at me this morning after a "get up and go" from a stop light.
Got to work and looked at my coolant level under the hood.. Looks fine to me.
I am about 200miles overdue of an oil change, (ya, I know) but that's about it.
Think my sensor needs to be replaced?
(2001 5sp 2.0)
* my coolant level is good
* fans are turning
* engine feels cool
Thanks~~
Burke~
Old 10-11-2007, 01:47 AM
2011 Honda Pilot EX-L
Car: white '99 2.0 GLS stick
Cool
While at running temperature, use EXTREME caution and check both radiator hoses for firmness and heat...
Old 10-11-2007, 02:22 AM
I have once seen a broken float inside the reservoir, causing the coolant light to be constantly on. Just take a look inside the bottle. Find some way to temp check the engine. I think if it was really overheating, you would know it.
Old 10-11-2007, 02:24 AM
Ok thanks.
At idle, its fine. Even after freeway and warning, I can come to an idle and wait a few -then it's fine.
But I'll look at that, thanks.
Ya, physically the manifold is fine (cooler than normal due to me running the heater at full blast "just in case")
Old 10-11-2007, 03:10 PM
Yeah the right tube is hot and soft, the left tube is cold and hard..
(standing in front of the car)
what does that mean?
Old 10-11-2007, 04:20 PM
vdubbugman53's Avatar
Arvada, CO, USA
you can also get the car hot and see if it looks like your coolent is ready to over flow
Old 10-11-2007, 04:29 PM
Which I think I noticed that as well.
.. (looked "too full" to me after it got hot - cold it looks normal)
Old 10-11-2007, 05:21 PM
thermostat not opening?
Old 10-11-2007, 05:35 PM
Well my heater is working.. that meant the thermo was working in my mustang 5.0 days..
but I'm not sure..
Could be stuck.
Where is it located (you have a pic?)
part # needed?
Thanks~
Old 10-11-2007, 06:01 PM
Arvada, CO, USA
when i lost my pump it my res got way full....thermo was working just pump was not pushing any water....my vote is on the pump...if heater is workin your thurmo is workin...thermo is on the left front side of the block. fallow the lower tad hose under the oil filter and it will come up in to the front of the block. you will see screws to take that off. it is i in there
Old 10-11-2007, 06:13 PM
Ok.
I just talked to a local repair guy. He said since my heater was working, that should mean my pump is ok...
I went outside just now and my coolant tank looked lower than it should, but got her hot and it looked way to high. The right radiator hose gets really hot, but that bottom one feels cool.
The little hose from the coolant tank feels like there is warm liquid in it.
hmm...
well, I have an appointment NEXT thursay.. earliest somebody can take a look.. bleh..
anybody here local to Boise/Meridian ID?
Old 10-11-2007, 07:32 PM
Turbo S: Who needs mods??
USA
Car: 2002 Platinum Gray Turbo S
I'm willing to wager it's the water pump. The age of your car puts it right where they start to fail. VW uses a plastic impeller and it ends up getting brittle and either spins on the shaft or falls apart. You may as well have the timing belt replaced if it ends up being the water pump.
Old 10-11-2007, 08:05 PM
Have a good link to a waterpump and belt?
Thanks.
(even ebay would be fine)
Old 10-11-2007, 08:07 PM
Arvada, CO, USA
get the whole kit from ECSTuning.com
Old 10-11-2007, 08:14 PM
is this right?
http://www.evwparts.com/Merchant2/me...=PassatCooling
ok, i'll check that site too. Thanks man.
Old 10-11-2007, 08:36 PM
well, talked to the tech again and asked if he had the water pump in stock. He said again, that since my heater works, that means the water pump is pushing water fine...
hmm..
man, I'm a Ford guy.. I have no idea on these Vdub's..
Old 10-11-2007, 11:06 PM
Arvada, CO, USA
yea it may be pushing some water. you may not have all the fins in tact...that is what happened to me...when mine went as long as i was driving in the city i was fine but if i got in the highway i would over heat just cuz i still have a few fins left on my pump
Old 10-18-2007, 09:49 PM
Yep, it was my impeller.
SO, I'm on about 70K miles and need that "60K service" thing done anyways.
so to do that and the new metal water pump, I am being quoted $800-900ish.
I have a K&N and just did the oil myself.
sound about right?
I heard, "cabinet filter, plugs, belts, rings, pump, " stuff like that.
sound ok?
(he may also do my new headlight bulbs.. since they are out. showed me how easy they where to replace...)
Old 10-18-2007, 10:48 PM
LadybugEwa's Avatar
PUNCHED BUG
Toronto, Ontario, Canada
I'd say that sounds more like a dealer quote than a 'local repair guy' quote, but maybe it's the greenbacks confusing me...
Here's a look at Ladybug
Coolant temp SALTYDOG1960 1.8 Liter Turbo 7 07-11-2007 04:36 PM
Temp warning light today Carphunter Questions, Issues, Concerns, or Problems with the New Beetle 5 05-01-2006 08:22 PM
Coolant Temp Sensor GaUdeNtiUs 2.0 Liter Gas 8 02-09-2006 10:14 PM
temp warning light questions blutopless2 Questions, Issues, Concerns, or Problems with the New Beetle 10 01-12-2006 03:12 AM
Lighting and coolant warning problems! gins beetle Questions, Issues, Concerns, or Problems with the New Beetle 10 10-02-2005 10:31 AM
