headlight adjustment question - NewBeetle.org Forums
Old 10-15-2007, 10:29 AM
englishman11's Avatar
Baker City, OR, USA
Car: 1998 New Beetle 2.0, 1968 Beetle, 2011 Ford Fiesta, 2003 Passat V6 4-motion wagon, 2000 Dodge Ram
Default headlight adjustment question
Hey everyone, hope all is well with you all (including your cars). I have a quick question: How do I adjust my headlights? Since I've had the car, they've always seemed to be pointed down too much. This is somewhat problematic when I'm driving on the freeway during night. I really hate to be the guy on the road that always has his high beams on... Any tips and/or suggestions are welcome.
Old 10-16-2007, 01:13 PM
Milford, MA,
Car: 1998 2.0 GLS
if you look on the inner sides of the headlight buckets, you'll see two white plastic (or gray plastic) hex-shaped screw heads. these are the adjusters. they're a bit counterintuitive to work, and are a bit of apin to get at, since one is occluded by the bucket retention strap, and neither offer a straight-on position for the screwdriver/hex socket/hex/key.
I had to sadjust one of mine and I wound up actually taking the headlight bucket out, so that I could figure out which way to turn the screws to get the thing to adjust correctly. (I actually wound up taking the lens off the bucket as well)
my Hanes manual illustrated the headlight adjuster positions. do you have a manual?
Old 10-17-2007, 08:10 AM
Baker City, OR, USA
Thanks for the advise. I had and idea those screws were for adjustment, but wasn't entirely sure.
I don't have a manual unfortunately. I really should get one.
Thanks again for the help.
Old 10-23-2007, 09:31 PM
Be extremely careful when adjusting the plastic screws if one happens to get overturned or pushed to hard it will break and the entire headlight assembly will need to be replaced!! Not a cheap mistake to correct...just ask my body shop.
Old 11-08-2008, 01:35 AM
macdave's Avatar
Olympia, WA, USA
Car: 01 1.9TDI Techno Blue
The top screw adjusts the height of the low beam, I can't figure out what the lower screw does.
The best way to turn them is with an extra long 6mm ball tipped hex key.
You can adjust the foglights using a T20 torx driver to turn the screw by the top of the light.
Old 11-17-2008, 08:20 PM
Beaufort, NC, USA
Car: 07 TripleWhite Convertible
I just re-aimed my passenger side lowbeam. The dealer had to replace that headlight unit (about $500 part) and of course they didn't aim it correctly. I could see the road 20feet in front of me very good though.
I had to use a T 40 torx, because my allen wrench wasn't long enough to fit straight it.....it just spun in the socket. The torx did great!
Old 11-23-2008, 11:52 PM
Default Adj screws not working?
The driver's side adjustment screws spin and spin (either direction) but don't actually change the direction of the beam. They have never worked (ie, I didn't start fiddling with it and broke it). I have taken the headlight out, tried everything I can think of. Using Torx heads, but can't tell you the size a the moment. I can confirm that the white "innards" spin against the black bucket. They just don't seem to turn anything at all.
I'm the original owner.
Old 11-28-2009, 01:42 AM
Baby Jai's Avatar
Default well
i can tell you i have been trying to get mine to go higher as wlel with absolutely no luck what so ever, its out of control how much of a pain it is to raise the distance
Old 06-21-2010, 09:14 PM
Fallon's Avatar
Ziggy's Mom
San Francisco, CA, USA
Car: 06 Salsa Red TDI Pkg 1 ("Ziggy")
Just found this thread... Does anyone have a picture of what this thread is talking about? I'm a very visual person, so I'm not really understanding what everyone's talking about. Or.... anyone know how much it costs to have a shop or stealership to aim the headlights for you?
Old 06-24-2010, 07:57 PM
Fallon's Avatar
Ziggy's Mom
Just FYI, stealership charges $80!!!! No wonder they call it the stealership! Dad and I will be attempting to aim them this weekend. I'll let everyone know how it goes. Made me want to go into an expletive tirade.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
Headlight question isotope_beetle Questions, Issues, Concerns, or Problems with the New Beetle 1 01-11-2008 07:32 PM
Headlight Adjustment/ Aim Switch.. ???? amari 2.0 Liter Gas 4 08-07-2007 05:45 PM
2001 NB Headlight question...among other things. theatredivachu Questions, Issues, Concerns, or Problems with the New Beetle 10 11-26-2006 11:23 PM
Headlight question - need answer quick! Jodokall Technical Modifications 4 01-21-2006 01:13 PM
headlight bulb question zenewie Technical Modifications 5 09-29-2005 07:48 PM
