Catalytic converter question - NewBeetle.org Forums
Old 11-11-2007, 11:56 PM
Default Catalytic converter question
I have a terrible noise, I really think it s the catalytic converter, I read the code at Autozone and it comes out as a fuel metering unit problem code but I heard that cat. problems come out under the same code: is that true?
Also: Do you know approximately the price of the job? Does anyone knows a good VW mechanic in Bakersfield, ca?
Thanks so much for your help!!!!!!!!
Old 11-15-2007, 11:20 PM
NE, USA
How many miles are on the car?
Old 11-17-2007, 02:04 AM
HudsonValleyVDub's Avatar
Hudson Valley Area, NY, USA
Car: Techno Blue 01 GLS 5 spd
Other than a broken internal baffel or external heat shield, a catalitic converter makes no noise...nor would either of those two cause a check engine light. There's no fuel metering going on in the cat so, I'd ask the dealer to be sure. BTW, what was the code exactly?
- Joe
Old 11-17-2007, 11:34 PM
gilligan's Avatar
MI, USA
I also am experiencing a horrible noise...like a broken loose
baffle, its probably in my resonator but its driving me nuts it sounds like a loose muffler clamp is just dangling and rattling on the exhaust pipe, but there are none. Its driving me nuts too!!!
Guess I know what cherry is getting for christmas....a new magnaflow catback.
Old 11-21-2007, 04:58 AM
NE, USA
It's probably your catalytic converter so a catback won't fix it
Old 11-21-2007, 06:16 PM
jazzcat's Avatar
Delightfully Tacky
Mesa, AZ, USA
Car: 1997 GTi VR6
but a straight pipe will
Jim
1997 GTi VR6..its cliche
http://rustisnotacrime.com
Old 09-14-2009, 11:00 PM
Hello just new here, hope to stay long. Thanks
Old 09-14-2009, 11:01 PM
By the way I need help. I was confused if the magnaflow catalytic converter is pretty good?and also where to buy? I do searched and I tried it here for some queries Magnaflow Catalytic Converter. Anyone tried it here.? Any suggestions, please let me know. Thanks.
Old 09-14-2009, 11:54 PM
Beetlecup's Avatar
senior member
Tampa / St. Petersburg, FL, USA
Car: 2003 Turbo S
I did get a check engine light from the exhaust system, stemming from the CAT. The so call "honey combs inside the cat" Broke away and clogged the exhaust outlet. Car was slow and because the exhaust couldn't escape. Mostly sounds like ratting in the exhaust system.
Catalytic Converter KNEWBUG New Beetle Convertible 8 09-14-2007 02:04 AM
Catalytic Converter? Sashira Questions, Issues, Concerns, or Problems with the New Beetle 12 08-01-2007 05:58 PM
Catalytic Converter Warranty Greta 2.0 Liter Gas 4 05-27-2007 01:26 AM
Catalytic converter on 1.8T 2003TurboGurl 1.8 Liter Turbo 3 03-26-2007 02:32 AM
Removing catalytic converter funky 1.8 Liter Turbo 5 03-04-2006 02:06 PM
