My husband did mine. Actually he did more than just the timing belt/water pump. Get your parts from here if you decide to do it.
http://www.metalmanparts.com/product...7&categoryId=8
Hello, Ah. Thank you for the reply. I thought it should be possible. I'm handy with a wrench and I've got the Bentley book on order. I'm no stranger to VWs. But I'm new to the NB. We just bought it used. So I didn't know if there were any gotchas that would prevent me from doing it myself. Thanks again. |
Others will reply too. I do know not to use the stretch bolts more than the one time. Other than that I have no secret short cut or insider tips. I was just a bystander
He did all the work with just the haynes book so you should be fine. Good luck! |
I was looking at that kit (with the G12 coolant) for $200. It seems like a fairly good deal considering the upgraded water pump. To save $600-$700 I sure will do the work myself Best regards.
Gosh, that engine compartment is tight!In the past: 2000 Miata LS -- 1996 VR6 GTI -- 1988 GTI 16V -- 1982 Toyota Starlet
You will need a "special" tool to hold the TB tensioner at the specified point--every other tool is pretty standard. An assortment of sockets, extensions, etc. comes in handy working the very cramped quarters removing the passenger side engine mount, at least the part bolted to the engine. I've done TB & WP jobs on 2.0 and 1.8T. The 2.0 is a bit easier.
Thanks! It wouldn't happen to be this tool, would it? http://www.ecstuning.com/stage/image...2/600/8162.jpg I must say; I'm very glad I registered on the org! Best regards |
Too bad you aren't in the Atlanta area - I only charge $250 and you bring your own parts (Metalman is highly recommended) ![]() As far as doing it yourself, my first time took about 7 hours - with experience it will only take about 4 hours on the 2.0L (a little longer on the 1.8T because of the aux waterpump pipe and pancake pipe). Some things to watch out for: 1. The allen head bolts that hold on the harmonic balancer are easy to strip (and many times are stripped from a previous timing belt replacement as I've discovered....) 2. Depending on the age of the car, the dipstick tube will most likely break while trying to change the thermostat - when you order parts, go ahead and order a dipstick tube. They cost $3. 3. If you are going to change the thermostat, you REALLY should buy a set of long reach ball-end allen sockets. Otherwise it can take longer to change the thermostat than the entire rest of the timing belt job. 4. I set the engine to TDC and use the "nail polish" technique just as added insurance. (Nail polish technque is where you mark the belt with a light colored nail polish at 3 locations to ensure the new belt is installed in exactly the same position). Here on the Org, I've heard some people claim it took them an entire weekend to do this job... but I'm guessing a LOT of beer was involved. Plan accordingly. ![]()
"The rich ruleth over the poor, and the borrower is servant to the lender." Proverbs 22:7
There was one I couldn't even remember or figure out what it was for at first.![]() |
Wow. That's great information! Many thanks to everyone for all the help. I hope someday I'll be able to return the favor Best regards. |
Hey grumblebunny, did you get the belt changed? How hard was it. I am looking to do this on my wifes car next weekend. I am nervous its a big job, but I certainly would like to save the money.
I was just quoted $1,300.00 by our local VW dealer. What a ripoff.
I will be ordering one of the $200 kits with accessory belt, timing belt, improved water pump, bolts, seals, gaskets and tensioner. I could do it myself, but found a local import shop to do it for $240. I figure that is worth doing since we just bought the car and they could look it over for any other issues. |
The dealer is a total ripoff for this service. I'm having a local shop do my timing belt, water pump, serpentine belt, air filter, and an oil change for ~$400. She's at the shop right now! And hopefully within the next week, I'll get her cabin air filter changed and spark plugs done myself, as well as giving her a well deserved bath. Doing work yourself is definitely a way to go to cut cost, but also look around for local, reputable shops.
![]() (i saw this thread and immediately thought of you.. and what do yah know.. here you are!) |
Here's what I paid for timing belt tensioner, and thermostat, parts and installation.
Bottom of bill was cut off when I scanned it, but the bottom line says $398.42. Water pump looked like it had just been changed before we bought the car so the mech didn't put it in. As you can see the car still needs some work.. |
| Water pump/Accessory Belt Problem. | Abs_VW | Questions, Issues, Concerns, or Problems with the New Beetle | 4 | 05-21-2007 07:05 PM |
| Timing Belt/Water Pump | freddyjim | 2.0 Liter Gas | 7 | 04-23-2006 09:47 PM |
| 2001 Bettle timing belt and water pump replacement | casper76 | 1.8 Liter Turbo | 4 | 01-10-2006 04:54 PM |
| Loss Of Power After Timing Belt and Water Pump Replacement... PLEASE HELP! | supercharged_v6 | 2.0 Liter Gas | 4 | 10-23-2005 06:58 AM |
| Timing Belt/Water Pump replacement question | Smileybug | Questions, Issues, Concerns, or Problems with the New Beetle | 5 | 10-22-2005 04:55 PM |
