Spark Plugs on a 2.0L - NewBeetle.org Forums
Old 02-23-2008, 07:32 PM
Default Spark Plugs on a 2.0L
Hey Guys..
Just thought I would let you all know about spark plugs on a 2.0L....it's really not as hard as it looks. I just replaced my plugs in about 25 minutes...and that included also replacing the serpentine belt and air filter. It's true that the #2 and #3 plug are a little more difficult to get to, it's really not too bad of a job to do. I didn't even need a flex joint on my ratchet to do it.
Anyway...Fear not fellow Beetle drivers...the plugs are easy to do and it's not a bad idea to do it every 64,000km. I bought the car in September and I couldn't find any record of the spark plugs being replaced. Bosch Platinum plugs came out of the car, which were not factory....so I guess at some point...the pugs were replaced...but the car calls for NGK Laser Platinums...and that's what I put it...right off the hop I noticed a smoother idle, better throttle response and smoother engine performance throughout the power band.
Cheers;
Peter
Old 04-02-2008, 05:05 PM
Quick novice question about changing plugs and wires: I've never changed spark plugs (or wires) before, and when I took off the engine cover just now it seemed like the plugs were pretty hard to get to. Did you remove any other parts to get to them, or use any special tools?
Thanks.
Old 04-02-2008, 07:43 PM
jbthompson's Avatar
Fort Worth, TX, USA
Yes, tell us more! I need to do this but am scared to!
Old 04-02-2008, 09:54 PM
antonym's Avatar
¯\_(ツ)_/¯ (o\_l_/o)
Car: 2013 Kia Rio-5
I didn't remove anything apart from the engine cover when I did mine. All you need is a longer extension... the #2 and #3 plugs are angled so the come out real nice...
The only thing to ensure is that you don't damage the plug wires if you are NOT going to replace them... they are a pain in the #$% to take off but with the right tool it should be easy...
I used regular pliers but gripped the metal "flanges?" on each plug wire in order not to damage the wires.
Old 04-03-2008, 11:05 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
Here is the spark plug wire removal tool that I use to when I change my spark plugs.
Old 07-28-2008, 12:15 AM
thegimpster's Avatar
Electro Tek Supreme
Bedford, IN, USA
Car: Mine 96 Jetta GLS, Wife 99 NB GLS
I have a long (12") pair of bent nose pliers that I use to pull them. In the Jetta I usually take the top half of the air intake off, I haven't done it in the beetle yet, that will probably be this weeks task.
Old 07-28-2008, 08:00 AM
vdubbugman53's Avatar
Arvada, CO, USA
i use a wire coat hanger to do mine
Old 07-28-2008, 06:24 PM
Brians2000Beetle's Avatar
Ocala, FL, USA
Car: 2000 Beetle
I just replaced mine last weekend. Used the long needle nose and snatched the wires off. I replaced the wires too at the same time. If the plugs are shot good chance the wires are there or close.
I too was relieved with how the plugs were angled : \ \ / / made it easy.
2000 VW Beetle GLS 5-spd Updates so far : Alpine IDA-X100
My Site : V-DubBeetle
Old 07-28-2008, 07:07 PM
My bf has the same tool as D2...no way he was getting to the #2 or #3 plugs...
Old 07-31-2008, 05:49 AM
Bob's Avatar
BobRegistered Member Bob is offline
Grand Poobah
Weyburn, Saskatchewan, Canada
Car: 2000 Batik Blue GLS
I'm in the same boat as digifant_gli, I went on here and saw everyone talking about their special tools and what not. Then I went out to the garage and 15 minutes later I had it done with just a ratchet and extension. If you put your mind to it, it can be done
Old 07-31-2008, 01:30 PM
Toronto, Ontario, Canada
Car: Acura RSX Type-S Turbo ;)
the only "special tool" i used was the sparkplug boot puller for $4 dollars. the one I bought looks like a screw driver with a circle-hook at the tip. the more expensive boot puller wouldn't fit #2 or #3 due to the size of the tool.
process is straight forward. I can't believe the shops around here want to charge $150 to change the spark plugs.
Old 01-03-2010, 01:02 AM
vdubing's Avatar
vdUbing
Locust Grove, Locust Grove, USA
Car: 2001 GLS
How did you make your tool?
Im not lazy i just hang out a lot.
Old 01-05-2010, 03:31 AM
KY, USA
Car: 2001
Is there a guide for how to change the sparkplugs? Flying blind here! I need pictures (or a tutorial) would be great!
Old 01-05-2010, 12:12 PM
antonym's Avatar
¯\_(ツ)_/¯ (o\_l_/o)
Car: 2013 Kia Rio-5
There you go...
Old 05-08-2012, 07:20 PM
Lovely step by step guide , Thanks
Why are VW spark plugs so expensive? jesse 1.8 Liter Turbo 42 07-02-2008 08:34 PM
spark plugs? robpad 1.8 Liter Turbo 3 10-02-2007 05:37 PM
Spark Plugs xhunter187 2.0 Liter Gas 5 01-18-2007 02:08 AM
70+ hp from spark plugs? Fowvay Questions, Issues, Concerns, or Problems with the New Beetle 17 09-21-2006 02:25 AM
Spark Plugs SIX SPEED 1.8 Liter Turbo 25 11-19-2005 01:34 AM
