Here are the codes that came up on Bella,she just sputters on take off but once she is warmed up everything seems fine....she is a 98 and a month ago we had the same problems,changed fuel filter and she was happy now we have the same problems all over again. spark plugs and wires were done 2 months ago.Could it be bad fuel? p1128 long term fuel trim B1 system too lean p0300 random misfire detected p0301 cylinder 1 misfire p0302 cylinder 2 misfire p0102 mas or volume air flow curcuit low input p0303 cylinder 3 misfire detected thanks goes out to anyone who can give me a few suggestions! Bella in BC |
Thanks for your suggestions,
would either explain why after running a month just fine then crappy again? If I had gotten some bad fuel a month back could I still be dealing with complications and why would it run fine for a month then ****ty now? its like something is clogged at start up then after a few pedal pumps and gentle speed she is up and running. thanks |
However, if you truly think it is bad fuel there may be some sediment in the tank; if this is the case I would suggest that you drain and flush the fuel tank and/or replace the fuel pump. |
Try to buy your gas at the same place. When I do my taveling I stick to the same places. A while back in Illinois on a couple of trips,I bought at different places,One place sold nothing but ethanol....I had no choice but to put it in.....I was on empty and no other places in site. I filled up and the car sputtered and coughed,After a few tries it started up and ran,This happened 2 times and I won't let it happen again. I stick with filling up at the 1/4 tank mark from now on. This gives me the option to shop around if they are selling the ethanol crap.
in colorado you cant get anything but ethanol
| Bella is a little sick | mcmac | 2.0 Liter Gas | 14 | 05-26-2009 01:28 AM |
| sick 98 beetle | llama_of_doom | 2.0 Liter Gas | 11 | 03-01-2008 11:04 PM |
| very very sick Bug... Help | Bug_Kev | 2.0 Liter Gas | 9 | 02-22-2008 05:36 AM |
| Sick Lilo :(.......... | bugsy98nb | The New Beetle Experience | 19 | 08-07-2007 03:56 PM |
| My car is sick | ETBUG | 1.9 Liter TDI | 16 | 07-03-2007 02:50 AM |
