Catalytic Converter - NewBeetle.org Forums
Old 03-30-2008, 06:52 PM
my99beetle's Avatar
my99beetle
portland, OR, USA
Car: 99 GLS
Unhappy Catalytic Converter
I have a 99 GLS with 105000 miles on it and my cat went out so I had it replaced at a local muffler shop and the engine light keeps coming on can anyone help me with problem. and ideas of why ? I love my beetle but its turning into a money pit.
Old 03-30-2008, 07:04 PM
NeedMoreHP's Avatar
same bug since 01!
O'Fallon, IL, USA
Car: 2001 GLS
did the shop clear the code? it could have come back on because it was never cleared. I'd start there...
NeedMoreHP
-Finally free of the crayon smell...turned out to be the sound deadening material/heat shield under the carpeting!-
Old 03-30-2008, 07:22 PM
my99beetle's Avatar
my99beetle
portland, OR, USA
Car: 99 GLS
the shop did erase all the codes but the light keeps coming back on. I had a after market cat installed could that be the problem ??
Old 03-30-2008, 08:36 PM
vdubbugman53's Avatar
Arvada, CO, USA
get an o2 spacer and that should end your problems
Old 03-30-2008, 09:09 PM
gilligan's Avatar
MI, USA
Not to mention find your receipt vw will repay you every penny you spent.
http://www.epa.gov/OTAQ/cert/recall/vw2.htm
Old 03-30-2008, 10:01 PM
Bob's Avatar
BobRegistered Member Bob is offline
Grand Poobah
Weyburn, Saskatchewan, Canada
Car: 2000 Batik Blue GLS
No way! I remember getting a letter from Volkswagen, then someone threw it away on me. So I'm guessing the catalytic converter I paid for last summer shouldn't of cost me that decent chunk of change? This hurts...
Old 03-31-2008, 02:50 AM
Arvada, CO, USA
they only covered the cat up to 100k miles
Old 03-31-2008, 04:59 AM
my99beetle's Avatar
my99beetle
portland, OR, USA
Car: 99 GLS
WOW I did not know that !! do I need to call the dealer or contact the EPA ? i would love to get my money back on this.
any more info would be great would sure help me alot.
Old 03-31-2008, 05:00 PM
my99beetle's Avatar
my99beetle
portland, OR, USA
Car: 99 GLS
volkswagen will cover the cat upto 10 years and 120,000 miles
you need to call volkswagen and give them your vin #
Old 03-31-2008, 10:08 PM
Picknicker's Avatar
Germany
Car: '99 2.0i
Maybe not only your cat was broken, maybe also a lambda probe went out...
Old 04-01-2008, 03:58 AM
my99beetle's Avatar
my99beetle
portland, OR, USA
Car: 99 GLS
Angry catalytic converter
well I call my local vw dealer today to ask them about the recall on my beetle they said they would replace my cat if it was still the factory cat, but if i had it replaced with a after market one that all they could is charge $85 to scan it to see if the cat was working ok. so they will only fix it if you have the factory cat still in there and its making noise
Old 04-08-2008, 02:19 PM
SF Bay Area, CA, USA
Car: 99 Beetle 2.0
my cel came on and my mechanic said it was the o2 sensor so we replaced both. the cel turned off but returned yesterday after only 100 miles of driving. wtf? im guessing now it could be my cat. at 150k i doubt if vw is gonna replace it for free. anyone know if they are leanient at all about 30k over their mileage limit? how about a non-oem cat that will work?
Old 04-08-2008, 02:51 PM
Arvada, CO, USA
im tellin you...space it out of the pipe a little bit..they make spacers for it.
no VW will not replace your cat at 150k..u run aftermarket with no problems
Old 04-09-2008, 05:13 AM
Car: 99 Beetle 2.0
got a link to an aftermarket cat? the ones i se online are specified not to work with CA emmissions
Catalytic converter question magfly 2.0 Liter Gas 8 09-14-2009 11:54 PM
catalytic converter- after market tom20682 2.0 Liter Gas 15 10-31-2007 05:02 PM
Catalytic Converter KNEWBUG New Beetle Convertible 8 09-14-2007 02:04 AM
Catalytic Converter? Sashira Questions, Issues, Concerns, or Problems with the New Beetle 12 08-01-2007 05:58 PM
Catalytic converter on 1.8T 2003TurboGurl 1.8 Liter Turbo 3 03-26-2007 02:32 AM
