Engine removal question - NewBeetle.org Forums
Old 04-08-2008, 05:19 PM
Default Engine removal question
I need to replace the engine in my beetle,The Hayes Manual says the engine comes out of the bottom of the car along with the transmission??? Can I split the engine and pull it out from the top. Is there a web site or FAQ that gives the procedure for removing the engine and a list of engines that will fit into a 1999 Beetle (2.0L). The Hayes manual has me jumping all over the book and I really don't trust the procedure.
thanks
Old 04-08-2008, 06:04 PM
vdubbugman53's Avatar
Arvada, CO, USA
pull the 2 fenders and bumper as 1 pice. then pull the actual metal bumper and pull the engine and tranny as 1 pice out of the front. any MK4 Engine will fit in there even the VR6 it all depends on how handy you are with tools and stuff. if you want a direct Swap then you need to find an AEG motor so you can still use your ECU. if the motor has secondary air injection (SAI) which a 99 shouldnt but if it does you will need another motor with SAI
Old 04-08-2008, 06:41 PM
Default engine removal
Thanks for the response and the pictures.
Since I already have everything off the engine I hate to go thru the extra step of takeing the whole fornt end off, although it sure looks easier to work on that way. I should have asked before I started the work. So I guess my questions is can I take "just" the engine out thru the top without the trans (automatic) The Hays book is telling me to take out the axles and drop the engine thru the bottom??
thanks
Old 04-09-2008, 03:23 AM
Arvada, CO, USA
yea if your not going to take the front off then it has to go down....or seperate then pull motor through top
Old 04-09-2008, 03:35 AM
builder's Avatar
"Are you damaged"
hey bugman, thanks for the pics, i too have a 99 that i may end up switching out the motor. i think it has a blown head gasket and i'm still battling with which route to take, you get into it and then find a cracked head or something like that. haven't had a vw since the air cooled days and picked up this 99 for a good price, it's just a toy right now but i would like to fix it right. any advice. i had coolant in the oil, drained it and started it just to hear it run, it actually sounds good, 117K. thanks again
Old 04-09-2008, 04:56 AM
Arvada, CO, USA
you oiled it before you started i hope haha....but pull the head which can be done on the car. replace the head gasket and see how she does
Old 04-09-2008, 10:13 PM
builder's Avatar
"Are you damaged"
just what i needed after a tough day at work . . a good chuckle . . yeah i did put in some fresh oil . . i reread my post and it did sound like i skipped an important step. to pull the head . . is that fairly straightforward or should i just go ahead . . bite the bullet . . and get a bentley . .
Old 04-09-2008, 10:31 PM
Arvada, CO, USA
well your going to need to know how to do a timing belt. You may as well do that since you have to take it off anyway. other then that it is 10 bolts i think that you need a special socket for.
Old 04-09-2008, 11:01 PM
builder's Avatar
"Are you damaged"
yeah, triple square socket . . new TTY head bolts . . gasket set . . belts . . new style water pump . . tensioner . . probably some other stuff . . what gets me in trouble is that i found a 60K motor for a grand . . decisions decisions . . anyway . . thanks again for the info
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
Engine Removal, 2000 GLS Turbo Turbosl2 1.8 Liter Turbo 5 10-07-2007 09:25 PM
question for anyone that has taken apart the engine badphish 1.8 Liter Turbo 0 11-20-2006 10:52 PM
Radio Removal Tools Question teklein Car Audio 2 07-17-2006 12:36 AM
Timing Belt Tensioner Removal Question GLXpress 1.8 Liter Turbo 1 06-12-2006 09:23 PM
