I'm trying to clear a p0117 code on my 99 2.0 NB, and I'm planning on replacing the coolant temp. sensor. I know there's a blue one and a green one -- how do I know which one my car needs? The Autozone people tell me the only way is to take out the sensor. Is there another way to find out?
Also, one of them is $7 and the other is $57. Have other people had the same experience? Thanks! |
You want the green one. There are two different shapes of it though. I think my '99 2.0 took one that was square. But in '99 I believe there was a switch of the shape to a D shaped senssor but I'm not sure on that one.
But I got my sensor and a new o-ring (which you really should buy with it!) for $25 at the dealer. It wasn't a very hard thing to replace either. You just have to make sure you depressurize the coolant otherwise it will come pouring out when you do the sensor ![]()
The Past Ride: Darla, 102k, '99 New Beetle GL 5-speed. Bone stock. Acquired 4/6/05. Gave her life for me 8/17/11. RIP ![]() The Project: Klaus, 180k+, '84 Jetta GL Turbo Diesel. Rebuilt and bringing 50+ mpg. Slightly improved from stock Acquired 7/12/08The Baby Brother: Günther, 120k, 20th Anniversary Edition GTI ![]() The money saver:2001 Jetta TDI GL. 117k. Dead auto, swapped to 3 pedals. Hubby's DD and our trip car |
Is it in a different place on the 2.0 than the 1.8t? If not you don't have to take off the engine cover. I'll search for noR's very helpful pic. BRB
I went to the Autozone yesterday, and they told me that there are three sensors available for a '99 2.0 Beetle. The sensor mine needed (the "C" sensor, which they determined was right for my car after looking at my car's VIN number) wasn't one that they had in stock, and it also wasn't one that they could order.
I'm not sure whether the "C" type sensor is the blue or the green one (though I don't suspect it's the green one, since that one seems readily available), and I'm also not sure where to get it. Ideally, I'd like to order/buy the sensor and the o-ring somewhere other than the dealer. Any suggestions as to where I might find these two parts? (I've already tried a few of the car parts sites, and none of them list a vehicle-specific sensor.) Thank you. |
I didn't think I'd run into trouble changing the coolant temp. sensor on my 99 2.0L NB, but I'm stuck.
First, I went to the dealer and bought a sensor. I gave them my car's registration so that they could give me the right sensor, and they gave me the green one. From what I can tell, though, they gave me the wrong sensor -- the one in my car is blue, and the terminals don't match. I have a "C" type engine. Does it sound like they gave me the wrong sensor? Second, I'm having trouble getting the old sensor out. I unplug the electrical connector, but I can't get the sensor itself out of the pipe. How does it release? I tried to pull up or push down on the piece of plastic that holds it in place, but I'm not having any luck. What am I doing wrong? Thanks! |
If you are changing the sensor that is where all the water lines come together, there is a little black C shaped clamp that slides into a slot about 1/4" down from the top of the pipe that the sensor sit in.
I have a 01 new beetle, and want to change the coolant sensor (see my earlier thread about blinko mclighto) but don't know which one I should get.
http://www.tdiparts.com/catalog/prod...roducts_id=396 or http://www.tdiparts.com/catalog/prod...roducts_id=351 how do I know which one will fit? |
you look and see which one you have
blue one is square connector black (superceded to green) has the d-shaped connector fwiw, the dealer will replace faulty black sensors with a green one.. i think the recently put out a recall or something.. |
I haven't heard of an actual recall. I had to pay to replace mine. I think I ended up with the square connector (dealer gave me the wrong one at first...even though I gave them all the info on my car...). I know there was a switch in like 2000 or 2001 to the other connector.
| Coolant Temp Sensor | Diognes56 | 2.0 Liter Gas | 11 | 08-07-2007 03:43 PM |
| 01 aph 1.8t coolant temp sensor 2 pin not 4 pin | tripen2 | Questions, Issues, Concerns, or Problems with the New Beetle | 4 | 10-25-2006 11:44 PM |
| Where is the coolant temp sensor? | DruzeTito | 1.8 Liter Turbo | 8 | 06-22-2006 02:35 AM |
| Coolant Temp Sensor | GaUdeNtiUs | 2.0 Liter Gas | 8 | 02-09-2006 10:14 PM |
| Hidden Coolant Temp Sensor | bedelbug | 1.9 Liter TDI | 3 | 01-22-2006 05:52 PM |
