What jobs can I combine? - NewBeetle.org Forums
Old 04-23-2008, 01:42 AM
Baton Rouge, LA, USA
Default What jobs can I combine?
The drivers side CV joint is out, what can be combined in that job? I would love to replace 2-3 things at once and not have to worry about taking the same thing back apart to do another job, or paying labor twice. With 140k miles, and a 19 year old as her previous owner, I can almost promise that most maintenance HAS NOT been the greatest, if done at all!
Old 04-23-2008, 05:16 AM
vdubbugman53's Avatar
Arvada, CO, USA
well check the breaks while your in there other then that, not much really has to happen to replace an axel
Old 04-23-2008, 05:45 AM
NBTurboFreak's Avatar
20V GTRS
Car: 2001 Sliver Arrow GLX
Brake lines, ball joint, tie rod ends, and control arm bushings for a few. Not that much harder from there to upgrade the dogbone mount with urethane bushings like from Autotech. Depending how far you want to go, strut, spring, wheel bearings, brake pads, rotors just for a few things on the maintenance side.
MySpace -- Piczo Pics -- WoW
HVWC 2010 Public Relations
Old 04-23-2008, 08:44 PM
Okay, so I'm only doing the drivers side. Common sense tells me that stuff like struts, shocks etc, needs to be done on both sides at the same time, right?
Old 04-23-2008, 09:22 PM
noR's Avatar
Administrator
Jackson, MS, USA
yes, that's right.
noR | me | Phrog
PHROG
Old 04-23-2008, 09:26 PM
Thanks. Would be best to go ahead and replace both axles? I "think" I'm getting a pretty good deal, $120 per axle.
Old 04-23-2008, 09:36 PM
noR's Avatar
Administrator
Jackson, MS, USA
Sounds like a good idea to me. Preventitive maintenance I suppose. I can't say I've worn out an axle, but if you've got one down to that point, maybe another wouldn't hurt just to be sure.
I'd do a visual inspection on all those parts NBTurboFreak mentioned. Maybe even before your appt. so that you can have the bushings in hand when the time comes?
Old 04-23-2008, 10:08 PM
20V GTRS
I have blown 4 passenger side axels and only 1 driver's side. I am hoping to get the Bildon axels by the end of the year, but till then I have 2 extra stock sets in my garage ready to go.
Old 05-16-2008, 05:34 AM
Tesla's Avatar
Y2K Speedle
Car: 2000 Beetle 2.0 Manual
Wink
Do as much as you can at once.
Do left and right at the same time or you will end up with steering wheel facing 35 degree left and car going straight or something.
Replace sway bar bushings and end links to smooth the ride.
Full control arms
If not struts and springs, then at least Strut mount bushings and bearings, top and bottom.
Wheel bearings are busted for sure.
Dog bone ( OEM for smooth or polyurethane to keep you awake )
And then there is the rear axle....
how deep down the rabbit hole you want to go?
Go out and ride
SPEEDLE
I'm changing jobs. jdesigns Miscellaneous Hoo-Ha 46 07-12-2008 04:06 PM
Custom Paint jobs. beetlebug 99 Paint and Body 8 04-11-2007 01:14 AM
great paint jobs k8thegr8 Miscellaneous Hoo-Ha Archive 8 02-06-2007 09:30 PM
My Jobs PhoenixRising Jokes 0 04-11-2006 07:49 AM
My Jobs PhoenixRising Jokes 1 03-17-2006 01:22 PM
