My cooling fans are not working. The fuses look good but they never turn on when car is warm. As long as I am moving it is fine but if I get into traffic it started getting warm. Is there some relay or sensor that is a known issue with turning the fans on?
Do they run when you have the air conditioner on? My '98 had the same issue, I tried replacing the temperature sensor in the cluster of hoses right by the block but that didn't fix it. I believe we also did the one in the radiator, but I'm not positive, because it was about 5-6 years ago. I later replaced both fans because they were getting noisy, that didn't fix it either. My fans worked with the AC on, so I just used the AC all the time, which isn't that hard to do when you live in South Florida.
I never found the cause, I tried 2 different sensors and the fans as well as the fuse panel on the top of the battery. I sold the car a few months ago, now I have an '05 with a warranty. I just ran the AC all the time, which was made for a mess and a parked car for a few days when the condenser went out.
Related Threads
VW Beetle Forum
979.7K posts
73.9K members
Since 2005
The New Beetle forum, come in and join our discussions on the new Volkswagen Beetle. Talk about modifications, performance and color choices.
