Hey folks. The beetle that I am working on has that code registered. I know it has to do with the air/smog pump system. I took off the plastic cover and then checked the air pump. It does not seem to be working. I therefore pulled the connector that goes to the pump, and then while having it attache to a volt meter checked for voltage on the connector/wiring harness an there was no voltage with the key on nor when the motor is started or running.
So is there a fuse or something (relay) that could result in the connector not having power? Does it supposed to have power while starting and running? My next step is to put 12volt on the pump and see if it runs, if it does then for sure the thing is not getting power. Thank you |
Really, only for a minute? Seems such a waste to put that pump and all that other stuff for it to run for a minute. I'll recheck it. Thanks for the tip. :O)
The vacuum hose for the brake power booster was loose, I took it out put some tape on the ends to snug them up until I can get a new one tommorow, and now the darn ABS light and brake light is on. It also beeps...lol Got a match and some gas? Didn't touch anything related to ABS, as far as I know. |
Did you pull the cover off the battery? There's a plug behind the wires & fuses that came loose on mine & threw the same codes. Pushed the plug back snug & no more abs& epc lights
Yes I actually did remove the cover. SPeaking of the battery how do I remove the entire cover so I can disconnect the battery and let the computer reset itself? Then I will attempt to put the cover back on and check for the location of that plug and make sure it is on correctly.
THanks so much for the answers! |
| WTB: Secondary Air Injection Pump | FallinApartBoy | Parts and Accessories | 2 | 01-26-2009 05:34 PM |
| Secondary Air Injection? | richardstanley | 1.8 Liter Turbo | 2 | 03-30-2007 04:48 PM |
| P1424 Secondary Air Injection System: Bank 1: Leak Detected | Just_Hackin | 1.8 Liter Turbo | 2 | 12-16-2006 06:25 PM |
| WTB: Secondary Air Injection Valve | 2000GLX | Market Place Archives | 0 | 06-15-2006 11:30 AM |
| Code help - 17832 Secondary Air Injection | bolwin1 | 1.8 Liter Turbo | 4 | 05-01-2006 03:20 AM |
