can anyone help me decode these codes please? - NewBeetle.org Forums
Old 05-17-2008, 07:22 PM
Default can anyone help me decode these codes please?
I've just logged these codes for my wifes' 2000 2.0 beetle, look like mostly grounding issues from descriptions. Trouble light is on: any guidance on how to remedy the problem(s) greatly appreciated! She had an issue with the car failing to start last night and occasional stalls at traffic lights.
Thanks in advance for any insights!
P1225
P1226
P1227
P1228
P1451
P1421
P1425
P1472
P0411
P1500
P0322
P0301
Old 05-17-2008, 09:35 PM
05yellowbeetle's Avatar
Middlesex, NC,
Car: Herbie '05 Yellow 2.0 GL
I would check the wires where they come through the fire wall. My brother ran into a girl at advanced auto parts with a beetle, the wires had melted and the car would not shut off even if you took the key out of the ignition.
Old 05-17-2008, 10:31 PM
marvins_dad's Avatar
I BELIEVE!
Dallas, TX, USA
Car: 2002 DIYCGCC TDI
P1225 - P1225 17633 Cyl.1-Fuel Inj.Circ. Short to Ground
P1226 - P1226 17634 Cyl.2-Fuel Inj.Circ. Short to Ground
P1227 - P1227 17635 Cyl.3-Fuel Inj.Circ. Short to Ground
P1228 - P1228 17636 Cyl.4-Fuel Inj.Circ. Short to Ground
P1451 - P1451 17859 Sec.Air Inj.Sys.Circ Short to Ground
P1421 - P1421 17829 Sec.Air Inj.Valve Circ Short to Ground
P1425 - P1425 17833 Tank Vent.Valve Short to Ground
P1472 - P1472 17880 EVAP Emission Contr.LDP Circ Short to Ground
P0411 - P0441 16825 Evaporative Emission System Incorrect Purge Flow
P1500 - P1500 17908 Fuel Pump Relay Circ. Electrical Malfunction
P0322 - P0322 16706 Ignition/Distributor Engine Speed Input Circuit No Signal
P0301 - P0301 16685 Cylinder 1 Misfire Detected
marvins_dad ~ antoine
Old 05-17-2008, 10:43 PM
vdubbugman53's Avatar
Arvada, CO, USA
get a new fuel pump relay that will fix a lot of that
Old 05-19-2008, 02:00 AM
Default thanks all
Thanks for the iput, I'll put in a fuel relay and test wiring this week
Old 05-19-2008, 07:44 AM
LadybugEwa's Avatar
PUNCHED BUG
Toronto, Ontario, Canada
On a 2.0 of that age, also suspect the wires and ignition coil (check for cracks in plastic housing).
Here's a look at Ladybug
What do these codes mean? BeetleCamry 2.0 Liter Gas 9 08-10-2007 02:21 AM
Need Help 2 codes Warnberg 2.0 Liter Gas 3 07-07-2007 03:23 PM
How do you get the CEL codes? dan 1.8 Liter Turbo 14 03-31-2007 04:56 PM
CEL codes-Help! zakattack95 2.0 Liter Gas 7 02-25-2007 04:58 AM
Please help decode this V.I.N. syco133 Technical Modifications 10 05-30-2006 12:27 AM
