Me (Erin) ~ My car (Curby)
I don't have the OEM filter because there's a p-flo sitting in there making vroom-vroom noises - otherwise I'd check it for you. Some writeups only call for removing 2 phillips screws on the cover of the air box. Others say to 'take off the clamp taking the hose and slide whole assembly out'
Maybe someone who has one could comment so we can get this sorted for you ![]()
1. squeeze the sides of this and disconnect it. 2. unplug this by pushing the little tab on the one side. it only goes one way, so you can't muss it up. 3. use channel lock pliers and squeeze this ring and push it to the one side. It's a PITA, but it's easier than paying someone to do it for you or buying the right tool. Use the biggest pliers you have. 4. unscrew the screws on either sides. one is way down real deep so use a long screwdriver with a magnetic tip or you'll lose it in the engine somewhere like me the first time. 5. (not pictured) there are 2 screws holding the MAF sensor to the airbox. They just unscrew if needed. Once the screws are out, the cover just comes right off. I might have overdone these directions. I think these directions are if you want to take the whole airbox out. If so, i'm sure someone will correct me. Either way, that filter will come out with these directions.
The big spring clips on the air tube / MAF are a PITA. You should try to locate a pair of vice grips to take them off. I only have a small pair of channel locks and they don't work as well as the vice grips do.
Hey Erin, how's your headliner holding up? Do you need to replace it yet?
Just kidding!Look at you, being all responsible with Curby! You're so sweet! He better be treating you right!
I'm J-Dawg, flyin' down the road in Paul McCARtney, the only Beetle in wings! Mi Bacca es Chewbacca! ![]() ![]() I'm one of those people. Whatever that means. |
erin, the screws that john is talkign about are on the FAR side of the airbox and are captive, they wont unscrew all the way.
to change the filter all you need to do is remove the two screws, tilt the top of the box forward, push it back toward the windshield and the lid will pop off enuf to get the old filter out. slide the new one in, hook the hooks back into the front places screw in the two screws and you are done
My dad is an electrician and has every took known to man except a pair of vice grips so I had to use his channel locks. It took me about 20 minutes to change mine but only because I had never done it before. |
If you still can't figure it out by tomorrow Erin, let me know. I have a stock airbox in my closet. I can help you out. I also have my Haynes around here somewhere too.
I'm puzzled why this isn't working out for you. ![]() For now, check for the other screw that i highlighted her with the arrow. |
I just did this to Violet a week or two ago. All I had to do was remove the 3 screws on the top, disconnect the two hoses (big and little) on the left side, then wrestle the cover off. It's really shoehorned in there.
It wasn't as much of a PITA to put it back on, you just have to make sure the tabs on the bottom (blue circle) all engage properly Good luck! |
Ya know Erin, I have had Jeeps and Sammies for many years and done a whole lot of work on them myself. Wired lights, hooked up dual batteries, added fuse boxes, relocated air boxes, done more suspension work than I care to remember, changed all fluids blablabla. But trying stuff on this Beetle totally freaks me out partly because of the cramped under the hood space and the seemingly fragility of a lot of the parts and the dreaded Check Engine Light if you screw up. I started to do this filter change one day and totally couldn't get the darn top to move far enough to get the filter out. I finally had to give it up and go back to it at a later date. But I did get it done. I used some needle nosed vice grips on that clamp.
The headlights, what's with that set up? Yikes! I really like the car, but I am not crazy about some of the stuff that goes with it. I do like to do my own work but I really think twice about doing some of the things I would like to do. Hang in there, at least here at the forum, everybody has done most everything and taken pix. It's a lifesaver and they are always encouraging.Tracy
REBA, Simply Red, down the road "Shorty" Pepper White 06 MCS |
| Things you might say to.... | boblamb58 | Jokes | 12 | 08-18-2007 04:10 PM |
| curby's getting his bumper painted...finally! | callisto9 | Paint and Body | 39 | 02-22-2007 10:10 PM |
| Things i should do? | jimcav | Questions, Issues, Concerns, or Problems with the New Beetle | 3 | 06-26-2006 03:35 PM |
| Ten Things Dad Will Never Say | PhoenixRising | Jokes | 0 | 03-24-2006 07:08 AM |
| Few '04 Things | enfusraye | Questions, Issues, Concerns, or Problems with the New Beetle | 0 | 11-24-2005 05:36 PM |
