Power steering awful leaking - NewBeetle.org Forums
Old 05-23-2008, 03:54 PM
Default Power steering awful leaking
i found there's a lot of fluid dropped from the steering boot gear area so can you tell me what is the problem coming from? It runs out of fluid every two days. how do i fix it?
thanks in advance
Old 05-23-2008, 04:55 PM
noR's Avatar
Administrator
Jackson, MS, USA
could be the steering box, could be a hose, not sure if it could be a tie-rod.
Check those out and report back.
noR | me | Phrog
PHROG
Old 05-23-2008, 10:37 PM
vdubbugman53's Avatar
Arvada, CO, USA
i will bet almost anything that your going to be looking for a new rack for sure
Old 05-26-2008, 09:45 PM
hi admin
I already took off the steering gear out and found there are full of stearing fluid inside the both of side stearing gear boots . hoses and the banjo bolts from pressure and return line at the stearing gear are OK. so where is the fluid coming from?
is there any gasket or o ring inside gear rack housing ? if yes how do we replace its?
thank you for your replys and help
Learn
Old 09-22-2010, 05:58 PM
Default leaky steering rack
sounds like you will need to replace your steering rack and pinion,, i think vw pinions are famous for leaking at around 140k miles
if you find a how to link on ring and pinion replacement let me know,, thanks
power steering ? bobaganoosh 1.8 Liter Turbo 0 10-13-2007 02:35 AM
power steering jimcav 2.0 Liter Gas 2 08-28-2007 01:27 PM
Help With Power Steering mezonesxbox Questions, Issues, Concerns, or Problems with the New Beetle 0 05-08-2006 08:35 PM
Power Steering Gone??? WhitePearl 2.0 Liter Gas 2 03-09-2006 08:14 AM
Power Steering Hose leaking Porkchop Questions, Issues, Concerns, or Problems with the New Beetle 1 02-26-2006 03:27 AM
