Engine start up sound. - NewBeetle.org Forums
Old 05-23-2008, 10:43 PM
johnlee6233's Avatar
Tacoma, WA, USA
Car: 1999 GLS 2.0L Memphis Audio White NB
Default Engine start up sound.
So I've got a little problem. This will happen randomly but when I start my car I'll get a loud squeal and just can't seem to find out what the hell it is. If anyone has had this problem fixed or know what it is please let me know.
Beetle Beetle Beetle
Old 05-24-2008, 12:58 AM
LadybugEwa's Avatar
PUNCHED BUG
Toronto, Ontario, Canada
Sounds like the serpentine/acessory belt. Does it do that only when you start it up, then stop after 10-30seconds?
Here's a look at Ladybug
Old 05-27-2008, 12:01 AM
vdubbugman53's Avatar
Arvada, CO, USA
if it goes away just after you let the key go when it starts it is your starter
Old 05-27-2008, 01:14 AM
Tacoma, WA, USA
k thx for the feedback. im gonna have to look into the starter then cuz it goes away soon after i let the key go.
Old 05-27-2008, 07:43 AM
LadybugEwa's Avatar
PUNCHED BUG
so it's the cranking sound you mean
Old 05-27-2008, 09:56 AM
Buglover's Avatar
I like yours too!
Adams,Tn., USA
If it's anything like mine....I get a "sqweel" out of my starter everytime I crank it up. It's been like that since I've owned it. A little annoying but it still works.
Old 05-27-2008, 03:19 PM
Arvada, CO, USA
yea new starter. should cost around 150. you can replace it your self as it is only 2 bolts
Old 05-27-2008, 04:05 PM
Buglover's Avatar
I like yours too!
Adams,Tn., USA
I say ride it out and just keep a little set back in case it does go out. Like I said in my other post.....Mine has been like that for years. If I'd get off my lazy a** I could just pull it and lube it up a little and that might take care of the problem.
Old 03-11-2010, 12:55 AM
Cool
I had the same sound. Only lasts about 1-3 seconds MAYBE after starting the car. I replaced the starter and it is still making the noise. Now I am looking at possibly the tensioner pulley or the serpentine belt. I checked the belt but it seems tight and doesn't look bad at all. Any feed back from anyone that has replaced the starter and still has this sound?
Old 03-11-2010, 01:45 AM
My starter is making noise but its not a squeal. How many miles are on the car? Have you replaced the timing and serpentine belts? I would lean towards a belt squeal than starter.
Old 03-11-2010, 07:50 PM
Canadianbugin's Avatar
Canadian New Member
Car: 98 N.B. 2L 5speed
Originally Posted by smileybug View Post
my starter is making noise but its not a squeal. How many miles are on the car? Have you replaced the timing and serpentine belts? I would lean towards a belt squeal than starter.
ditto......
Old 03-11-2010, 08:17 PM
Pierce County, WA, USA
Car: 2000 GL
That squeel is "most likely" the starter bearing going bad.
I assume its worse in cold mornings.
It goes away after the car has initially started.
That bearing is bad, replace starter.
JohnLee, I am also in Tacoma! U.P. to be exact.
Shoot me a PM I can give you some good spots for work and parts. I might even be able to do it for you.
Old 03-11-2010, 09:26 PM
Canadian New Member
Check your accesorie belt first....???? That would be the logical place to start would'nt it...??? Why would you think it's the starter...???? Could also be the SAI (Secondary Air Injection) This system only run's when the engines COLD and only for a few seconds.... Food for thought... Before you start replacing stuff diagnose the real problem... Instead of wasting money thoughing parts at it will not solve the problem...?????
Old 03-12-2010, 02:43 AM
mloeks76's Avatar
Scottsbluff, NE, USA
Car: 2002 VW Reflex Silver New Beetle Turbo S
VW dealership told me this week that in about 5 percent of cars, the timing belt will squeel before it breaks. Have you had your timing belt done lately?
If you have a squeeling timing belt, he recommended not driving it or little driving (like to be fixed) until you get it replaced.
I'm new to the Beetle world and don't know alot, but figured sharing the info might help.
Old 03-12-2010, 02:50 AM
OH, USA
Car: 03 GTI
The tensioner pulley may squeal if the bearing is going or if it's locked up the back side of the belt will squeal as it slides against the pulley. I had that happen to me on a Mk.2 Jetta--it didn't take long to wear 1/2 way through the belt from the back side!
Old 03-12-2010, 03:11 PM
Car: 2000 GL
Its the bearing in the starter. Just replace the starter and get a new one. When they do that, they are typically drawing more "amps" then they should be.
Stock rating is 140 amps, I would assume your in the upper 150's and 160's. Time to replace.
Old 03-12-2010, 06:57 PM
Canadian New Member
JUST so everyone know's the OP started this in 2008 and has not posted back since SO I'D SAY THIS IS A DEAD THREAD....?????
Old 03-12-2010, 07:58 PM
Car: 2000 GL
LoL! Never seen that.... oops...
Old 03-12-2010, 11:29 PM
Canadian New Member
What a waste of my time....
Old 03-13-2010, 02:35 PM
Car: 2000 GL
Some people's kids...
Engine sound/protection pan 2000GLS Technical Modifications 4 02-12-2008 03:04 PM
Old Beetle Engine Sound Hopkins The New Beetle Experience 4 05-18-2007 11:34 PM
Engine Rev on start up digitalputty Questions, Issues, Concerns, or Problems with the New Beetle 7 04-27-2007 01:50 AM
Need help with engine sound FineExampl 2.0 Liter Gas 22 05-18-2006 08:33 PM
Buzzing Sound After Engine Shutdown?? flat4tom 1.8 Liter Turbo 5 02-09-2006 04:22 PM
