Use this DIY for Fuel Filter change - NewBeetle.org Forums
Old 06-13-2008, 09:19 PM
antonym's Avatar
¯\_(ツ)_/¯ (o\_l_/o)
Car: 2010 Kia Forte EX 5spd AT Fuel Eco Opt
Default Use this DIY for Fuel Filter change
http://forums.vwvortex.com/zerothread?id=1276409
Yes folks! Its me again posting my latest acomplishment. I only just changed my fuel filter (at 94,363 miles ) using the above DIY writeup from vwvortex.com.
All that is needed is a little patience.
I must add some comments:
1. Jack up the car - things will be much easier if you can stick your head under there to see whats going on.
2. Unclip the cables that are in the way.
3. When removing the bracket around the filter, don't just loosen it... you have to take it off!
4. Remove the clip nearest to the rear tire FIRST (or the rear clip)! To get the front clip you have to genlty pull the whole filter down after you remove the rear clip to see where the little thing is to press down.
5. BE PATIENT... and gentle! It is not hard to do, it just takes a level head.
Should take under 15 mins.
Old 06-13-2008, 09:50 PM
jazzcat's Avatar
Delightfully Tacky
Mesa, AZ, USA
Car: 1997 GTi VR6
didn't even jack my car up when i replaced mine good write up though
Jim
1997 GTi VR6..its cliche
http://rustisnotacrime.com
Old 06-18-2008, 04:11 AM
HarlequinPixie's Avatar
ElectricHarleyHouseOfLove
Charlotte, NC, USA
Car: 2001 Batik Blue 2.0 GLS 5spd
that was pretty handy. i'd already ordered my filter before finding this.. my main issues were not being able to get the car to stall after removing the fuse and running it. the l'il trooper just would not give up.. so i just shut it off and hoped for the best.
thankfully the way i was twisted to see what i was doing (it was after work and getting dark under the car), I managed to avoid the face full of petrol I would've gotten. My arm got soaked, but I'm okay with that.
I'm impressed with how much smoother the engine runs\idles now.. I have no idea how long ago it was changed, if ever.
This Space Intentionally Left Blank
Old 06-19-2008, 05:06 AM
antonym's Avatar
¯\_(ツ)_/¯ (o\_l_/o)
Good Job Dude!
I also got a much smoother idle and my wife kept giving me the eye because she has been telling me for a while that the car did not sound right.... she has an ear for these things...
Old 08-09-2009, 09:51 PM
Landenberg, PA, USA
Car: 1998 NB, 2005 Mini cooper S
After 1 1/2 hours, I finally gave up trying to change my fuel filter. Even knowing where to press the "magic button" didn't help. As hard as I pressed that thing, I still couldn't pull off the fuel lines. I used as much force as I felt was reasonable, short of breaking the clips. After all the work I've done on this car (timing belt, AC compressor, etc) it is depressing to be defeated by a simple fuel filter.
Bug won't start after fuel filter change Shamrockez 1.9 Liter TDI 6 05-16-2008 07:06 PM
Hello, fuel filter change question here. kindsounds New Member Forum 5 04-18-2008 02:00 AM
First time Fuel Filter Change geezerb 1.9 Liter TDI 3 05-01-2007 03:20 PM
tip to make fuel filter change easier basskleff 1.9 Liter TDI 1 04-25-2007 07:33 PM
Question: How to change fuel filter 1pt8t 1.8 Liter Turbo 11 06-06-2006 03:51 PM
