radiator fluid leaking somewhere, common locations? - NewBeetle.org Forums
Old 06-20-2008, 09:29 PM
savethebluths.org's Avatar
Super smart senior member
Houston,
Default radiator fluid leaking somewhere, common locations?
That red blinky light keeps popping on and now its more frequent so Im sure there is a leak. What are possible common sites for leakage?
Old 06-20-2008, 09:32 PM
jazzcat's Avatar
Delightfully Tacky
Mesa, AZ, USA
Car: 1997 GTi VR6
check where your hoses connect to the radiator, check your plastic fluid reservoir for cracks..
pretty much anywhere that the coolant goes or connects to something check for leaks..check your oil too for coolant because that means you lost a head gasket
good luck
Jim
1997 GTi VR6..its cliche
http://rustisnotacrime.com
Old 06-20-2008, 09:36 PM
Houston,
good luck
Ill run a check and probably just replace all the tubes this weekend.
Did an oil change yesterday and luckily found NOTHING but oil in the pan yayy me.
Old 06-21-2008, 01:18 AM
LadybugEwa's Avatar
Bug me again!
Toronto, Ontario, Canada
Car: 2012 Turbo, RED of course!
If it's leaking very slowly from the rad like mine did, there's good chances you'll never see it on the ground. Mine pooled on a sort of lip that's there on the underside of the car, and dried into a pink crust that couldn't be seen until you stuck your head under the car and looked straight up.
Here's a look at Ladybug
Old 06-21-2008, 01:54 AM
MiG's Avatar
LkäPORSCHE
I smell coolant under my hood after long drives but, very faintly. I wonder if it might be a small leak also.
LkäPORSCHE
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
Where is the radiator fluid container beetlebgyrl Questions, Issues, Concerns, or Problems with the New Beetle 4 09-02-2007 09:30 PM
Radio Install Locations............... Smooth Car Audio 1 05-22-2007 12:27 AM
radiator fluid: can i use any coolant? jaylay 2.0 Liter Gas 5 02-12-2007 05:20 PM
CD changer socket locations BeccyBug Car Audio 4 10-19-2006 01:26 AM
Fuse locations piper109 Technical Modifications 0 04-09-2006 07:31 PM
