2000 beetle won't start/doesn't turn over... - NewBeetle.org Forums
Old 06-20-2008, 10:34 PM
sunshine219's Avatar
Unhappy 2000 beetle won't start/doesn't turn over...
2000 vw beetle 2.0 manual, turn the key ,dash lights come on, all aux items come on, but the car will not turn over. Replaced the starter, it tested okay but was loud..the battery was tested okay,replaced the negative battery cable and cleaned and tighted the positive cable. The battery is sending 12.48 to the starter and you can hear the solenoid clicking. We have checked the fuses under the hood and under the dash. The relays under the dash, something clicks when you try to start it and somthing besides the solenoid clicks under the hood... I checked the clutch swithes, the normally closed one works (clutch pedal switch starter lock relay)it opens when the clutch pedal is depressed.
the clutch pedal position switch, normally open, does not react to the peddle movemnet at all. How do I test the addition relays that are in this circuit? Also could it be my key??? The steering column locks sometimes and sometimes doesn't...the door locks work somtimes sometimes don't.. The alarm will go off when I put my key in to start it sometimes,when it was starting, nothing now.
I have had this car a total of 3 months! I have had a gm gas hog for 7 years have done more work on this 3 month owned beetle.
Any help would be appreciated!!
Old 06-20-2008, 10:52 PM
2015 Acura TLX
Car: white '99 2.0 GLS stick
Cool
Turn the ignition to the "ON" position. Do your power windows, turn signals and other accessories that operate with that key position function at all?
Alan
Old 06-20-2008, 11:47 PM
Default dead beetle...
yes, all the aux functions work...the battery was out of the car for 3 days and the radio did not lock out like the manuel said it would, could the theft warning system starter lock relay be the culpit and how do I test it? I am not sure which relay it is, under the dash,driver side is as far as I got.
Thanks for the help..
Cindy
Old 06-21-2008, 12:05 AM
2015 Acura TLX
Cool
Glad the aux functions operate. My thought was running to fried wires at the ignition switch. You may still have a fried wire to the starter wire spoke at the ignition switch (but you ARE getting clicking from the solenoid so I'm betting that this particular wire is o.k..
Once I purchased a "new" battery from my local auto supply store only to have it be defective after much angst and more $$$.
I don't have any more wild goose chases for you to embark on for now, but keep us posted on what you find out...
Old 06-21-2008, 01:07 AM
Default solenoid
I was wrong, the solenoid is not clicking, a relay in the engine compartment it clicking...
Old 06-21-2008, 05:18 PM
Default disconnected wires in the steering column!!
Thanks Margaritaville; got in there to check the ignition and there are wires disconnected in the steering column. An obvious sloppy repair. It is definitly a problem, I hope it is the problem!!
Thanks again, I'll keep you posted.
Cindy
Old 06-21-2008, 07:46 PM
Thumbs up an ignition wire loose was the problem!!
It is fixed,someone had spliced into the ignition wiring and did not crimp both ends of the connector. When I moved the steering column I pulled one end out of the connector and the car would not start. When I tried to start it after the wires were repaired, the anti theft locked the ignition and the radio. After about 10 minutes it unlocked.no dealer visit was needed this time anyway. I think I will take it for a ride!
Old 06-22-2008, 12:32 AM
LadybugEwa's Avatar
Bug me again!
Toronto, Ontario, Canada
Car: 2012 Turbo, RED of course!
Here's a look at Ladybug
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
My NB won't start on the first turn of the key liquid_cocaine Questions, Issues, Concerns, or Problems with the New Beetle 6 01-03-2010 05:33 PM
beetle won't start Carphunter Questions, Issues, Concerns, or Problems with the New Beetle 10 08-27-2007 03:22 PM
98 New Beetle Won't Start emilyswing Questions, Issues, Concerns, or Problems with the New Beetle 5 05-31-2007 04:31 PM
it takes more than one try to start my beetle liquid_cocaine 2.0 Liter Gas 0 07-10-2006 07:38 PM
Beetle Won't Start - Help Please jiffyjoe Questions, Issues, Concerns, or Problems with the New Beetle 3 10-02-2005 12:26 PM
