Killed my 2.0? - NewBeetle.org Forums
Old 06-30-2008, 07:03 PM
Las Vegas, NV, USA
Car: 1999 GLS
Exclamation Killed my 2.0?
1999 new beetle
Problem started a couple days ago.
Noise was coming from area of timing belt gear cover.
Was driving it to work the next day and the engine started to overheat and the noise turned into a loud whining and then the car just shutdown.
I go to turn over the engine and start it and the starter spins and nothing else happens. Timing belt and serpentine is still intact.
I fear that everything is mangled internally?
Old 06-30-2008, 07:21 PM
bugasm99's Avatar
OG Stalker
Philadelphia, PA, USA
yup, you broke your timing belt. Depending on the rpm at which it snapped you may or may not have bent your valves, but their is a very good chance you did.
Old 06-30-2008, 07:34 PM
Las Vegas, NV, USA
Car: 1999 GLS
I just pulled off the timing belt cover and the belt is not broken.
I'm thinking the water pump is ceased up? ..... On a further note the coolant reservoir is empty also and there is evidence of oil and coolant from the top of the engine sprayed all over the hood.
Is there any way to tell if I bent the valves without taking the engine apart?
Old 06-30-2008, 08:02 PM
jazzcat's Avatar
Delightfully Tacky
Mesa, AZ, USA
Car: 1997 GTi VR6
just because the belt looks good doesn't mean the teeth on the gear are good
Jim
1997 GTi VR6..its cliche
http://rustisnotacrime.com
Old 06-30-2008, 08:06 PM
Lmhansen's Avatar
Revere, MA, USA
Car: 1998 New Beetle 2.0L, 2003 Pontiac Vibe
Check the fusebox in the engine compartment to see if something melted. It'll be hard to see if the fans are working if the car won't start, but NB's are notorious for overheating, and no coolant in the reservoir means it got really hot ...
Old 06-30-2008, 08:19 PM
noR's Avatar
Administrator
Jackson, MS, USA
I think it's the waterpump that failed.
noR | me | Phrog
PHROG
Old 06-30-2008, 08:20 PM
bugasm99's Avatar
OG Stalker
the waterpump on these vehicles is not strong enough to stop the timing belt. It would either strip the blades off or would strip the teeth off of the belt. If there is oil and coolant on the hood, there is a chance you overheated and warped the head which is allowing the fluids to spill out between the block and the head.
you can pull a spark lug and try to look inside with a boroscope or a light and small mirror (difficult) to see if the valve is bent or there are any marks on the piston crowns from the valves hitting.
Old 06-30-2008, 08:46 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
Did you pull the bottom belt cover off as well and inspect the entire timing belt?
Of course given your oil and water mix description it could be just a blown head gasket. Are the fluids evenly spread across the hood or heavy on one side and lighter as it goes across the hood?
Old 06-30-2008, 10:39 PM
Las Vegas, NV, USA
Car: 1999 GLS
I did not get around to pulling off the bottom cover. This is definitely where the timing belt is 'jammed'.
The fluids created an even line on the bottom of the hood right above where the timing belt is.
The top gear where the timing belt goes around has no teeth missing.
Old 06-30-2008, 10:43 PM
Las Vegas, NV, USA
Car: 1999 GLS
no fuses blown on top of the battery.
I did flip the timing belt upside down and the belt is stripped clean and the top gear is locked up
I think I bent the valves also?....
bugasm99's Avatar
OG Stalker
edit since I just read your last post. If the belt is stipped clean that would be your problem. I would replace the belt and pump, and spin the crank using a wrench to see if your pistons bottom out. If that checks out perform a compression test. Your valves may be safe after all.
Old 06-30-2008, 11:01 PM
Las Vegas, NV, USA
Car: 1999 GLS
I just spun the timing gear with a wrench two revolutions and it feels smooth and feels like it has compression.
Old 06-30-2008, 11:05 PM
Las Vegas, NV, USA
Car: 1999 GLS
I was looking for instructions on replacing the water pump is there any on this website or elsewhere?
Old 06-30-2008, 11:36 PM
Las Vegas, NV, USA
Car: 1999 GLS
So was searching around on the forum and found this thread:
Help troubleshoot this engine noise...
With this video.
This is the same noise that started this whole mess.
http://www.youtube.com/watch?v=VUKz4DveiA0
Republican almost killed me! Fowvay Miscellaneous Hoo-Ha Archive 26 11-07-2006 03:46 PM
I killed bambi. MrMeatCleaver Miscellaneous Hoo-Ha Archive 12 08-18-2006 01:24 AM
Friends Daughter and child killed :( bugsy98nb Miscellaneous Hoo-Ha Archive 19 12-20-2005 10:58 PM
i killed a bug!!!!!!!!!!!!!!!!!!!!!!!!!!!! v-dubed 1.8 Liter Turbo 3 10-18-2005 03:44 AM
