Follow up to killed my 2.0? - NewBeetle.org Forums
Old 07-07-2008, 07:02 PM
Las Vegas, NV, USA
Car: 1999 GLS
Question Follow up to killed my 2.0?
The original post was this:
Killed my 2.0?
The problem ended up being the water pump blades shattered.
I have dug out most of the blades but I know there are still some in it.
Any suggestions on making sure I got all of the broken plastic out?
I am afraid that I may cause damage to the now water pump if I do not get it all out.
Old 07-07-2008, 07:57 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
Wow! Is the impeller shaft bent?
Other than flushing the cooling system I know of no other way.
Old 07-07-2008, 09:16 PM
05yellowbeetle's Avatar
Middlesex, NC,
Car: Herbie '05 Yellow 2.0 GL
yikes.
Old 07-07-2008, 10:09 PM
Las Vegas, NV, USA
Car: 1999 GLS
yes it looks to me that the force of the impeller breaking and falling apart jammed it, bent the shaft and shattered all of the blades.
Ignition Coil ... Follow the misfire Scarab 1 Questions, Issues, Concerns, or Problems with the New Beetle 5 11-26-2007 05:48 PM
Kaiser Is The Man Follow Up kellyshair Miscellaneous Hoo-Ha Archive 3 05-30-2007 06:39 PM
How the TC/Oprah follow up should be angelworks Miscellaneous Hoo-Ha Archive 4 02-17-2006 09:12 PM
i killed a bug!!!!!!!!!!!!!!!!!!!!!!!!!!!! v-dubed 1.8 Liter Turbo 3 10-18-2005 03:44 AM
