The wheel bearings come with the hub attached to them. You will need to pull the old hub and bearing off the stub axle and replace the assembly. It's not that easy with out proper equipment. My drivers side bearing went a couple thousand miles back but it didn't solve all the humming and vibration. The rest was from worn tires (still show 3/32) that just got noisy as they aged. All tires get noisier as they age. Each heat cycle ie... cold (sitting all night) to hot (driving for a few miles) ages the tires a bit more.
So by the time you get down to 4/32 or so the tires usually develop a whole symphony of noises and are less able to deal with rain blah blah blah. So ya. It could actually be both. Not sure how that's supposed to cheer you up but there it is. |
Good going! What about rear axle bushings? Still want to replace them? I did mine a month ago and it was a mess!!! We had to melt them down all the way and then use dremel tool to cut the cylinder so we can slide it out. They were completely busted, and with the new ones riding is way less noisy ( no clonking ).
Good luck! |
| Rear wheel hub | cep | Questions, Issues, Concerns, or Problems with the New Beetle | 8 | 01-07-2009 07:15 PM |
| wheel bearings | robpad | Questions, Issues, Concerns, or Problems with the New Beetle | 8 | 04-10-2008 05:18 PM |
| Rear wheel bearings 2002 NB | Skoobahead | 2.0 Liter Gas | 1 | 07-09-2007 01:23 PM |
| Rear Wheel Drive | duo2999 | Technical Modifications | 16 | 01-12-2007 06:07 PM |
| Rear Wheel Bearing Replacement | newbugger | 1.8 Liter Turbo | 6 | 08-14-2006 01:33 PM |
