Thermostat Location? - NewBeetle.org Forums
Old 07-31-2008, 06:24 AM
Bob's Avatar
BobRegistered Member Bob is offline
Grand Poobah
Weyburn, Saskatchewan, Canada
Car: 2000 Batik Blue GLS
Question Thermostat Location?
I'll spill all the beans here, but my first question is where is the thermostat located on the ole 2.0? Someone said it was in the plastic housing where it goes into the block... but I just changed that when my coolant temp sensor quit and cracked that baby open. There was no thermostat in there... does the coolant temop sensor work as a thermo stat? I work on trucks I'm not used to this dinky stuff, haha.
Also I would like a second opinion before I go ahead and change my water pump/timing belt. After I overheated and cracked the plastic piece that goes to the block, I needed coolant to make it home, all I could get was some stuff that was garaunteed to work with anything... well it didn't it made a mess of my antifreeze. So I drained it all, took it to the shop where I work, and did my own little flush, running it for 30 minutes with water flowing through it. Thinking this would solve my problem I went to fill it up. It would not take nearly what it was supposed to, and my overheat light came on before I made it a block towards home. Just after my sensor went I DID hear some weird noises under the hood that went away. I'm thinking it had to be my water pump dying.
Moral of the question... am I right in changing my water pump and timing belt that needs changing. Or should I be changing my thermostat and/or go for a even better flush of my lines? I'm tired of having a lawn ornament.. haha.
Old 07-31-2008, 12:34 PM
D2Beetle's Avatar
No NB Yellow Trifecta :(
Springfield, TN, USA
Car: Sliver '00 GLX Turbo / Yellow '14 Fiat 500L / Black '15 TSI Turbo
Follow the top radiator hose from the radiator to the block; that is where the thermostat is.
Old 07-31-2008, 12:39 PM
Garage
You might be due for a change regardless. Has it been done and if not, what is your mileage?
Old 07-31-2008, 03:50 PM
vdubbugman53's Avatar
Arvada, CO, USA
im not gunna lie it is a pretty ****in stipid job just for a T stat
EDIT: when i say stupid i mean it will be a royal panin in the ass and you might throw some ****. i know i did
Old 08-01-2008, 02:40 PM
Bob's Avatar
Grand Poobah
Alright, so the top rad hose goes into that... super Y that splits with 4 hoses attatched to it and goes into the block. The thermostat is in there?? If so, my car never even came with one, because I changed that when it cracked from overheating and there was nothing to be seen.
Old 08-01-2008, 02:42 PM
Bob's Avatar
Grand Poobah
About 160,000km or 99,000miles ..the time when everything dies on a car.
Old 08-03-2008, 10:36 PM
savethebluths.org's Avatar
Super smart senior member
Houston,
Made a nice pic for ya
Nevermind the gauges, im testing my AC system.
Its behind a little shroud with 2 bolts going into the engine.
Old 08-07-2008, 07:47 AM
Houston,
Hmm for some reason the pic went bye bye.
heres another.
Old 08-07-2008, 03:20 PM
D2Beetle's Avatar
My mistake, it is the "other" radiator hose... sorry
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
Thermostat in 03 1.8t beetle? nightcrawler_20003 1.8 Liter Turbo 7 03-14-2011 03:11 PM
Thermostat location jpatter2 2.0 Liter Gas 1 10-16-2007 04:24 PM
thermostat? Kitchen 2.0 Liter Gas 4 09-29-2007 01:08 PM
1.8T Thermostat location? devioushaze 1.8 Liter Turbo 1 04-25-2007 05:21 AM
1.8T Thermostat location? devioushaze 1.8 Liter Turbo 1 04-25-2007 04:31 AM
