2001 2.0 wont start! - NewBeetle.org Forums
Old 07-31-2008, 10:09 PM
Default 2001 2.0 wont start!
Was running like crap recently, checked the codes and found both a cylinder misfire and an O2 sensor malfunction. Changed plugs and wires, still haven't redone O2 sensor. Plugs were pretty bad, seems like they had never been done and since sensor was failed was likely running rich.
Tried to start her back up afterwards, and she wont. Turns over, but feels almost like theres no fuel now. Hooked code reader back up, now getting P0321... checked every sensor i could find just to make sure i hadn't disconnected anything accidentally. still wont start, same code.
Surfing forums found that the code apparently means crank position sensor... (may be wrong) if thats the case would that stop the engine from starting?
Old 07-31-2008, 10:34 PM
lounge_bait's Avatar
Youngstown, Ohio, USA
Car: 8-ball - Black 2001 Sport
Sure would!
it happened on my '98 that i had.
good luck with it!
Overheated and now wont start dodge22racing 1.8 Liter Turbo 32 06-10-2008 05:28 AM
Car wont start if is not jumped with other battery. denisse 2.0 Liter Gas 16 06-06-2008 11:35 PM
Electronic Immobilizer?? car wont let me start. akaPRINCE Questions, Issues, Concerns, or Problems with the New Beetle 5 02-17-2008 06:34 AM
Another Car wont start thread 66busdriver 1.9 Liter TDI 4 12-23-2006 03:21 AM
Wont start, P0301 tonybalido 2.0 Liter Gas 11 08-01-2006 11:56 PM
