Cracked Fog Lights - NewBeetle.org Forums
Old 08-30-2008, 01:09 AM
silverpodgirl's Avatar
Silverpodgirl
Carmichael, CA, USA
Car: Silver 2001 GLS 5 speed
Default Cracked Fog Lights
Both of mine are cracked/broken with pieces missing from being hit by rocks. Is it really a 2-3 hour job at the shop? I have had a couple of mechanics tell me that, but now have someone saying he can do it in 1 hour. I heard that the front of the car has to be removed to get to the fog lamps. Anyone know?
Thanks
Old 08-30-2008, 01:30 AM
_goREDgo_'s Avatar
San Antonio, TX, USA
Car: '01 GLS "Red"
i had to get one of my fog lights replaced a month ago (it died) and it didn't take too long. about an hour and a half. but he did also replace one of the headlight bulbs as well.
'01. gls. 2.0. uni-red.
"picture me rollin'..."
Old 09-02-2008, 01:42 AM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
If you want it done by the book, then the front end has to come off. If the shop you take it to has never done one before, it could possibly take long.
However the front end does not have to come off if you only screw in the bottom mounting screw and use plastic tie-ties for the top mounting holes. At most it is a thirty minute job using this method. This is what I did on the wife's NB when I replaced the lower grille and both fog lights after she hit a deer.
Old 09-09-2008, 04:58 AM
I replaced the passenger side fog light on my girlfriends 2001 2.0 about a year ago. I don't have jacks so I just drove the passenger side onto a curb so that I could crawl undernieth the car. There is a couple of clips behind the fog lights. It took me less then an hour to do. Also, if you need help changing the head light here is a website you can go to: http://www.midsouthvw.com/TechTips/t...BeeHdlitRR.htm
It took me about twenty minutes to replace.
Cracked cupholders Tiger1963 Questions, Issues, Concerns, or Problems with the New Beetle 9 08-06-2009 06:46 PM
cracked berry! Tinkerbell Miscellaneous Hoo-Ha 8 06-15-2008 03:15 PM
Help Cracked Hose ID Crystalgolem 1.8 Liter Turbo 7 01-24-2007 02:57 AM
cracked windshield angelusnhc Paint and Body 13 01-20-2006 02:48 PM
cracked bumper! itsabugslife! Paint and Body 2 01-13-2006 09:32 PM
