A/C Wont work after changing spark plugs - NewBeetle.org Forums
Old 09-01-2008, 07:48 PM
Default A/C Wont work after changing spark plugs
After changing the spark plugs the A/C fan will not come on, have changed out the three fuses everyone talks about on the forum, any other suggestions?
Old 09-07-2008, 01:42 AM
Car: 2000 glx 2.0l
hi
did you remove anything while installing the spark plugs?
Old 09-07-2008, 06:16 PM
No did not remove anything tht we didnt put back immediately, also have chaned out the 3 green fuses that are on top of the battery , nothing looked burned or scorched, as seems to be a problem on this modfel. Just out of the clear blue wont work. seems odd. thank you
Old 09-08-2008, 12:33 AM
Car: 2000 glx 2.0l
If you had romoved any part of the intake,
your throttle adaptation will be out of alignment.
It will not throw a CEL.
The tell tale sign is that the A/C will work, only when
over 2300rpms.
If that is the case, vag-com is required.
If not, "I got nothin"
Jeff
Old 09-09-2008, 02:59 PM
Jeff, thank you, will the Hanes repair guide tell me about setting the trottle alignment and about the vag-com? Just a dad trying to fix his kids car, Thanks for your help.
Old 09-09-2008, 05:04 PM
LadybugEwa's Avatar
PUNCHED BUG
Toronto, Ontario, Canada
There's a simple procedure for 'throttle body readaptation'.
It's posted on here somewhere. It's just a turn of the key in ignition, to the second 'notch' for a few seconds.
Here's a look at Ladybug
Changing spark plugs AK Red Bug 2.0 Liter Gas 10 12-14-2008 11:59 PM
Is there a "How to:" thread on changing spark plugs? pinktimbs Questions, Issues, Concerns, or Problems with the New Beetle 5 11-07-2007 06:42 PM
Changing spark plugs on 2.0 Cricket Questions, Issues, Concerns, or Problems with the New Beetle 2 11-04-2007 06:35 PM
I tried changing my own spark plugs :( Kitchen 2.0 Liter Gas 13 06-09-2007 03:29 PM
NB Won't Start after Changing Spark Plugs kev716 Questions, Issues, Concerns, or Problems with the New Beetle 2 05-30-2006 04:56 PM
