A/C Fan just quit working - NewBeetle.org Forums
Old 09-03-2008, 02:31 PM
Default A/C Fan just quit working
A/C fan quit working out of the clear blue, have checked the three green fuses and replaced them, nothing looked burned or scorched, the fuse box is fine. Have an appointment to take it to the shop later this week, any suggestions? The light on the recirculation button comes on when you push the button but other than that, the entire heat/cold system seems dead. If the freon is low will that casue this to happen. Live in the desert and have not added freon in 2 years, the A/C was very cold befoe it died.
Old 09-04-2008, 01:41 AM
zeroelus's Avatar
former owner
Mexico
Car: Previously a 2K 2.0 litre GLS
I once had the AC just quit on me.. Wouldn't do a thing. The stealership said it was de HVAC controls and ordered that part. It was replaced and it did solve the problems.
Recently the car developed an issue where on idle it would blow cool air, but as soon as the engine was revved, it would stop working. I took it to a AC shop and the replaced a valve in the compressor's clutch if I remember correctly. Got it working again.
Good luck!
Old 09-07-2008, 01:47 AM
Car: 2000 glx 2.0l
hi
Do you have cruise contol on your bug?
If the cruise stopped working also, it is most
likely the throttle adaptation, it will require
alignment.
Fog lights quit working on 2001 NB? Fusible link? LauraLadyBug Questions, Issues, Concerns, or Problems with the New Beetle 2 07-12-2008 01:31 PM
odometer quit working....help!!! heatherm Questions, Issues, Concerns, or Problems with the New Beetle 4 04-14-2008 02:20 PM
Stereo just quit working this morning??? bigsexyTDI Car Audio 12 06-22-2007 01:07 PM
Gas door quit working.... Beetlebomb Questions, Issues, Concerns, or Problems with the New Beetle 4 01-22-2006 05:09 PM
