Additional Gauges for a 2.0 Auto? - NewBeetle.org Forums
Old 09-14-2008, 02:49 AM
Frapp's Avatar
Luna
Bellingham, MA, USA
Car: 2000 2.0L Batik Blue GLS Auto
Default Additional Gauges for a 2.0 Auto?
I was thinking the other day at how much it bothers me that I don't have actual engine temperature data other than Blue, Off, or Explosion Imminent.
I'm milling over adding one of those temperature gauges to my Bug (2.0 2000 Automatic). Is this a good idea or am I going to be giving off the "ricer" vibe? If not, are there any other gauges I could add?
Does anyone have any advice on the subject?
Thanks a lot!
Luna 2000 2.0L GLS Batik Blue; Automatic. Check Her Out!
Old 09-14-2008, 04:23 AM
WhatTheVDub's Avatar
That LGBT Member..
Pensacola, FL, USA
Car: 1998 New Beetle 2.0
I too was thinking about this the other day. An no I don't think you'd be giving off the ricer look, as long as you don't by some flashy gauge like auto meter's cobalt series. An opt for mounting it on your steering column with a gauge cup or a steering column pod(not sure if the golf one will fit).
http://store.summitracing.com/egnsea...=KeywordSearch
Old 09-14-2008, 06:14 AM
vdubbugman53's Avatar
Arvada, CO, USA
i on a stock 2.0 auto i would deffinatly want a water temp guage and maybe an oil temp gauge....then after that oil pressure or volts
Old 09-14-2008, 09:13 AM
Frapp's Avatar
Luna
Bellingham, MA, USA
At the risk of sounding dumb, I have to ask. Other than the Water Temp, what would I use the other gauges data for?
I really don't know much about cars or engines, so all this stuff is new to me.
I've also done some research on the boards. I'm considering going with the highly suggested Neuspeed Supercharger for a low-cost boost in power. Should I get a Boost Gauge or is that only for engines with a turbo thingamajig?
Old 09-14-2008, 03:32 PM
Arvada, CO, USA
if you get the charger you deff want a boost gauge and an oil pressure or oil temp gauge. other then water temp the other stuff is just there to make sure all is normal.
Additional padding for arm rest? BloodThirsty Styling Modifications 1 04-30-2008 01:13 PM
Installing Additional Gauges - a few questions... digifant_gli Technical Modifications 4 11-24-2007 05:52 AM
Euro switch mods - adding additional lights vgmnstr Technical Modifications 11 09-19-2006 04:24 AM
Timing belt change additional info ottoman 2.0 Liter Gas 2 07-21-2006 07:24 PM
Additional chat room for technical discussion iScott Suggestion Box 14 07-11-2006 07:37 PM
