Running sound when car is turned off?? - NewBeetle.org Forums
Old 11-13-2008, 05:22 PM
Chinadoll's Avatar
Ashtabula, OH, USA
Car: 2000 silver GLS
Question Running sound when car is turned off??
I have a question and maybe u guys can ansewer it for me, sometimes when i cut my car off, it still sounds like it is running. Havnt driven my car for 2 days, go outside and it sounds like its running, pop the hood and it looks like it could be a fan in the front of the car is spinning?? I have no clue what is goin on! Can somebody please help???
Old 11-13-2008, 05:30 PM
Tesla's Avatar
Y2K Speedle
Car: 2000 Beetle 2.0 Manual
After running the car for some time in hot conditions (or idling), computer will start the fans to cool down the radiator. When you turn off the engine, fans will continue to spin until sensor send the signal to the computer to shut it off, whether the engine is running or not. So that,s normal and usually the fans run few minutes after the engine is shut off. If the fans are running for long time ( say 10 minutes ) your temp sensor is most likely busted.
If the fans start spinning out of the blue you should check your temp sensor or thermostat or something like that. Someone here will jump in and point out which part might be busted.
Hope that helped
Go out and ride
SPEEDLE
Old 11-14-2008, 04:49 PM
Chinadoll's Avatar
Ashtabula, OH, USA
About how much is it gonna cost me to get that fixed?
Old 11-14-2008, 05:07 PM
Garage
Temp. sensor is cheap. Less than $30 and an easy DIY job.
Old 11-14-2008, 05:31 PM
Tesla's Avatar
Y2K Speedle
Find some vw service ( not the dealership ) and ask them for estimate. Should be less than 100 bucks if its thermostat or some temp sender.
Here is a diagram of all the engine sensors and senders.
Number 13 is my guess.
Good luck.
(2) 06A919081D
oil pressure switch
1,2-1,6BAR 1 pin black M10X1 / AEG,AQY,AVC, AWH,APK,APH, AYD,AZG,AWV, AWU
(2) 036919081A
oil pressure switch
0,3-0,6BAR 1 pin green M10X1 /
(2) 038919081A
oil pressure switch / F >> 9C-X-919 700*
0,7BAR M10X1 1 pin / ALH
(2) 038919081
oil pressure switch / F 1C-X-430 801>>* / F 9C-X-919 700>>*
0,55-0,85BAR 1 pin brown M10X1 / ALH ATD,ALH
5 N 0160241
sealing plug
M10X1 /
6 N 0138115
seal
A10X13,5 /
(10) 059919501A
dual temperature sender
4 pin green / AYD,AZG,ATD
(10) 078919501B
dual temperature sender / F >> 1C-X-430 800* / F >> 9C-X-919 699*
4 pin blue 20MM /
(10) 059919501A
dual temperature sender / F 1C-X-430 801>>* / F 9C-X-919 700>>*
4 pin green 20MM /
(11) 357919369E
thermal switch / for switching off air conditioner / and/or / electric fan
112/119C 20MM 112/108C 4 pin brown 3 stages / AHL
12 191919369A
thermal switch
119C 20MM 2 pin greywhite / air condit.
(13) 357121140
plug
14 032121142
retaining spring
15 N 90316802
round seal
19,6X3,6 /
19 02A919835
sleeve / switch for reversing light / F >> 9M-Y-000 001*
28 853919562
switch - altitude corrector
/ AVC,APH
29 N 0139694
oval head panel screw
B4,8X16 /
32 1J0907660B
oil level sensor
33 038103196
seal
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
one bleep sound when igition turned off???????? bertybug Questions, Issues, Concerns, or Problems with the New Beetle 10 02-03-2009 09:55 PM
My dearest BB turned 100,000 Breez Miscellaneous Hoo-Ha 16 07-05-2008 10:58 PM
Stability control - can it be turned off? bnoland 1.8 Liter Turbo 8 12-13-2007 01:21 PM
Hissing sound when car is turned off (Speaker) SIX SPEED Car Audio 2 05-31-2007 02:06 AM
It just turned off..... nyum96 1.8 Liter Turbo 7 07-11-2006 11:20 PM
