I was trying to reset the Check Engine Light and when I disconnected the battery positive cable, and reconnected I lost the radio. It says SAFE on the screen and none of the controlls seem to work. There is no sound, no FM or AM. I haven't figured out what to do, anyone know?
Thanks |
You need your radio code and your manual for how to key it back in. If you don't have your radio code, you need to get it from the dealer based on your VIN. Be advised that some dealerships charge for this. There is a member here who might be able to get it for you. Do a search for "radio code" and you should find it. Its a fairly recent thread.
Your radio is in safe mode. The code will restore the functionality.
Susan has it.
Note however that disconnecting the battery cable will NOT clear a CEL. In addition...you shouldn't have just removed the positive cable. Always remove the negative terminal first to avoid a possibly shocking situation. ![]()
Yeah. Some may not understand this so here's the skinny. The negative side is "grounded" to the car's body, so if while handling the positive battery terminal you touch any metal component of the car you could complete the circuit--battery negative side thru car body and thru you to the battery's positive side. OUCH. |
| Positive Battery Cable | jazzcat | 2.0 Liter Gas | 2 | 05-06-2008 08:45 PM |
| Positive Battery Cable? | swell | Questions, Issues, Concerns, or Problems with the New Beetle | 1 | 10-23-2007 09:50 PM |
| how to pull the battery cable off? | u2u2u2 | Questions, Issues, Concerns, or Problems with the New Beetle | 4 | 10-01-2007 06:17 PM |
| Battery fuse box cable, little acid spill | Dorado | Questions, Issues, Concerns, or Problems with the New Beetle | 2 | 10-17-2006 02:25 AM |
| Need help removing the radio | dyturbo | Car Audio | 0 | 12-31-2005 03:49 PM |
