Drive Cycle Needed for OBDII Malfunction - NewBeetle.org Forums
Old 12-15-2005, 09:32 PM
Bugged in CA's Avatar
Default Drive Cycle Needed for OBDII Malfunction
I today had my 1999 New Beetle 2.0 engine checked for California smog certification, A few days ago I think I corrected a cylinder 1 misfire and reset the CEL. The car today passed the emissions test, but failed the "functional check". I was told the OBDII monitors were unset (probably because of my erasing the error code) and I needed to perform a "drive cycle" which could "probably" be accomplished by driving the vehicle for five to seven days and a hundred or so miles. If not done correctly they will have to do the drive cycle and it will cost me $165!!
My question is does anyone know the "drive cycle" reset procedure for my vehicle. One article I read stated that the only source on this is published by Motor Manuals.
Also, if my cylinder number one misfire was not corrected, but the CEL light does not come on would it pass the smog check even if there was an error code reported?
Thanks in advance. :-)
- Really Bugged this time
Old 12-16-2005, 08:34 AM
180 Degrees out of faze
Central Coast, CA,
Car: 98 TDI NB.
The problem is with all of the readiness codes not being set. When you cleared the CEL, you also reset the rediness codes. Some get set just by turning on the key and the computer doing a self test. Others require you to "drive" the car through a number of cycles. A cycle is starting out with a cold motor, and driving until it is warm. You must go at least 45 MPH in the cycle. Then let it cool down, and do it again, and again. Usually takes about a week of just normal driving.
Old 12-24-2005, 05:54 AM
ttupper's Avatar
What's in a title?
Anaheim, CA, USA
Car: 2001 GLS
Most NB codes reset after 3 cycles. I live in Clifornia so that takes me a bout 1 day.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
NewBeetle.org Charity Toy Drive CrazyJames Site News 44 12-18-2005 09:48 PM
What Is The Deepest Water You've Had To Drive In? 06 Gecko Green New Member Forum 6 11-27-2005 02:48 AM
Computer hard drive Don_n_Herbie Market Place Archives 29 11-03-2005 12:21 PM
Lights dim when i drive? WHY? jesse 1.8 Liter Turbo 12 10-03-2005 04:45 AM
