Timing Belt Kits w & w/o Tstat - NewBeetle.org Forums
Old 01-03-2009, 01:09 PM
Virginia Beach, VA, USA
Car: 1998 VW Beetle
Default Timing Belt Kits w & w/o Tstat
Hi all,
I have done some searches for the Timing Belt change and I am finding some kits that include thermostats and gaskets and others dont. Some kits include Motor Mount Bolts, others dont.
Thus far, ECS Tuning has been the best price/shipping cost.
I was discussing the job with a mechanic and he mentioned that while doing the job I should also replace another part. I think he called it the water outlet, as this was made of plastic as well and was often the root of plastic impeller failure. Does any one have a source for this?
Thanks in advance.
Kyle
Old 01-03-2009, 03:43 PM
That would be the water pump, and yes it should be changed too. Get one with a metal impeller.
Old 01-04-2009, 03:44 AM
Growler's Avatar
strange things are afoot
Columbus,, OH, USA
Get the ECS deluxe kit with the motor mount bolts and the two bottles of coolant.
I installed one of these kits today for Beej and it was complete and parts were very good.
~Aaron~
Old 01-04-2009, 03:55 PM
antonym's Avatar
¯\_(ツ)_/¯ (o\_l_/o)
Car: 2013 Kia Rio-5
Same here...
ECS is the best value.
Old 01-05-2009, 06:50 AM
OH, USA
Car: 03 GTI
Originally Posted by krm944 View Post
...a mechanic and he mentioned that while doing the job I should also replace another part. I think he called it the water outlet, as this was made of plastic as well and was often the root of plastic impeller failure...
I believe the mechanic is referring to the outlet pipe behind which the T-stat mounts. They are fairly cheap and are prone to crack with aga/heat cycles just like the water pump. Get it from the dealer, they are a cheap part and come w/ a new O-ring already installed--do not overtorque!
YES, I did it! - Timing belt, water pump, accessory belt. antonym The New Beetle Experience 22 10-11-2011 03:50 AM
Timing belt kits Don_n_Herbie 1.9 Liter TDI 7 10-07-2008 10:05 AM
Timing belt/water pump kits...best one? Audiophil 1.8 Liter Turbo 4 10-09-2006 12:48 PM
Timing Belt Kits And Other Parts Metal Man Market Place Archives 7 02-10-2006 02:29 AM
