99 GL heat shield rattle? - NewBeetle.org Forums
Old 01-26-2009, 02:32 PM
slugbugminneapolis's Avatar
minneapolis, MN, USA
Car: 99 GL with extras
Default 99 GL heat shield rattle?
my 2.0 gl has this rattle that sounds like a catalytic converter heat shield is loose. ive looked under the car, but they look good. is there a heat shield on the exhaust manifold that you cannot see without using a lift? or does/has anybody had this issue? thanks for all the advice in advance.
Old 01-26-2009, 02:47 PM
HarlequinPixie's Avatar
ElectricHarleyHouseOfLove
Currently: Williamsburg, VA, USA
Car: 2001 Batik Blue 2.0 GLS 5spd
Apparently the Cat Converters on the early years had problems and got the warranty on them extended to 10 years\100k(i think) miles.. I just got mine replaced because it was sounding pretty much like you describe. might wanna check with a dealer to see whether yours is still covered.
Old 01-26-2009, 03:02 PM
the rattle issue seems to be inside the cat then? that would make sense since i cant find anything loose. most def not under warranty, but would love to pay to get rid of rattle, should i stay with a stock cat if it needs to be replaced or should i go aftermarket to save money?
Old 01-26-2009, 04:47 PM
OH, USA
Car: 03 GTI
http://www.epa.gov/otaq/cert/recall/vw2.htm
Warranty extension is to 10 yrs. and 120K miles. Do you fall under that? If not, aftermarket cats aren't too bad pricewise. I suggest going to an independant muffler/exhaust shop with a new cat in hand to get installed if you can't handle it yourself. There are other heat shields on the exhaust that you'll want to check before spending your hard-earned dough. If the cat is actually going bad you should have a check engine light--most likely code is P0422 I believe.
Old 01-26-2009, 04:58 PM
engine light is on, does a normal obd-2 reader work on the vws?
Old 01-26-2009, 05:18 PM
Lnzbug's Avatar
MINI & NB FOR LIFE!
Arlington Heights, IL, USA
They work fine. A vag-com would be better but they also cost more
Old 01-26-2009, 05:31 PM
as i plan to keep this car awhile, and do alot of the maintenance myself, would this other scan tool be a good investment, and if so where do i get one and about what should they cost?
Old 01-26-2009, 11:13 PM
oh wow. saw in your new member post that you'v e got 178,000 miles.. yeah. guess that's definitely out of warranty then!
Oil Pan Shield NeedMoreHP Questions, Issues, Concerns, or Problems with the New Beetle 18 09-30-2011 10:30 PM
Heat Shield 'nuts' missing ERICWC Questions, Issues, Concerns, or Problems with the New Beetle 2 08-10-2008 08:54 AM
Rattling Heat Shield Fix? ERICWC Questions, Issues, Concerns, or Problems with the New Beetle 5 07-24-2008 04:11 AM
heat shield on top of catalytic converter petah 2.0 Liter Gas 3 06-24-2008 03:31 PM
Eurosport Intake Heat Shield phatbeetlebug Market Place Archives 6 03-09-2007 01:40 AM
