Filter is accessible from outside, it's ahead of the right rear tire.
Have you heard the noise while outside or only when inside? |
Pull up your back seat & see if it's louder. I heard mine for a while before it finally bit the dust leaving me stranded. Might just be the regulator not the pump itself.
I hear it both inside and outside of the car. I think It's a bit louder outside.
Lnzbug: Is regulator build in fuel pump assembly? I looked under the seat, and only place that may be hiding something is fuel pump cover. Well, I've found lots of cereal, crackers and spare key from previous owner, but that's different story ![]() |
Des is right. Change the fuel filter first. It might be restricting the flow. It's located outside under by the passenger door. The fuel pump is under the panel you see under the back seat. It's sitting right in the top of the gas tank.
Had the exact same sound with the same types of noise.
Its not the filter. VW mechanic heard the noise and told me it was common in 2001 to 2005 2.0 beetles. My car started to have the problem at 30K miles. I replaced my fuel pump and the noise went away. The job is easy and you can do it yourself. Get a good pump though. Don't get some no-name brand from the local auto store. Always replace the fuel filter if you have to replace the pump. |
Seems like with fuel level going down in tank, sound is going away too... Fuel filter will be replaced tomorrow anyway. alg: Where did You get fuel pump? Pump in Autozone is like $320!! For $95 I could buy Walbro 255 LPH fuel pump kit for my WRX. Can You buy Walbro kit or something like that for Beetle? I googled it, and not much came out... Mario |
I got fuel filter replaced today.
Bought FF777 fuel filter from Autozone for about $18, which according to catalog is designed for 04 Beetle. I crawled under the car, and found ... something different. Went back to Autozone to return it, cause that only FF they had for 04 Beetle. So I went to VW stealership, where parts guy explained to me that Beetle have two different fuel filters/fuel systems. The one I have is Fuel Filter combined with pressure regulator! So it have 2 connectors on IN end, and one connector on OUT end. That's why price a "bit" higher - $48.99 ![]() He warned me also to be careful disconnecting fuel lines from filter/regulator. They brake easy. So I went back to my place. Took me about 15 minutes to figure out how to disconnect them... I almost gave up ![]() Filter sits in plastic bracket, and it is attached with metal band. To take it off use philips scredriver. I'll try to take picture showing what to press to release lines tomorrow. It is plastic ring, sitting at the front of fuel line connector(like ring in piston). You have to press it towards center of the fuel line with small screwdriver, and pull lines loose from filter. There was some fuel leaking, so make sure You got some kind of bowl. Installation is easy, put filter back, tighten the metal band, push lines onto connectors, until You hear CLICK. Start the engine, and make sure there is no gas leaking anywhere. DONE Sound I was talking about went away. Filter I pulled out, has never been replaced before. So in my case filter/pressure regulator was making that noise. Filter I pulled out was slightly different from what I got from stealership. Old one was probably part U can service or adjust, I'm not sure. So it was build from 2 parts, held together by kind of spring. New one was one solid part. New filter box/part number: ![]() Old filter: ![]() Old filter pic 2: ![]() Picture of new filter can be found here: http://www.simply-parts.com/S-Pcat08...%20Filters.pdf Hope this will help to ones that don't have service manuals ![]() Mario |
I'm trying to replace my fuel filter on my 99 Beetle and I am having a heck of a time releasing the line on the front of the filter. The tab thing is on top and it's giving me problems. Any advice? I've been trying to use a small screwdriver (like my mechanic told me to), but with the angle and not a lot of room, I just can't get it.
Mario |
Huh, I thought I had to release the lines before I got it out. I'll try it! Thanks!
No luck. Could there be a bunch of gunk in there, keeping the tab from releasing? If so, how can I get it out? I'll have my husband give me a hand tomorrow, unless you guys have more ideas.
ETA: I can turn the filter in the line, if that makes any difference. Last edited by woolybugger; 02-03-2009 at 12:36 AM.. |
If not... MAybe some kind of oil, and leave it for night to soak pretty good. I wouldn't use WD40 tho, since it could damage polyurethane bushings, I would afraid It can be bad for these clips, or O-rings. Just try to use something like... cooking oil... ![]() Also compressed air may be good idea. Just my ideas... Good luck |
This was useful when I replaced mine. I used the screwdriver and just started squeezing and they both popped off.
http://forums.vwvortex.com/zerothread?id=2979787 |
Now, let's hope she starts. |
| air pump filter? | mat3833 | 1.8 Liter Turbo | 19 | 04-16-2008 04:52 PM |
| Fuel pump noise, replace it? | alg | Questions, Issues, Concerns, or Problems with the New Beetle | 4 | 02-23-2008 02:56 PM |
| Oil Pump Noise | nyum96 | 1.8 Liter Turbo | 0 | 04-12-2007 08:49 PM |
| air pump problem cause a p1137 long term fuel trim (add) fuel bank 1 system too rich | jerry kuntzman | 1.8 Liter Turbo | 4 | 09-13-2006 04:22 PM |
| secondary air pump filter??? | malibu350 | 1.8 Liter Turbo | 2 | 06-30-2006 06:26 PM |
