Starts then dies - NewBeetle.org Forums
Old 02-06-2009, 11:38 AM
Default Starts then dies
2003 convertible. Recently replaced battery. Car starts fine then immediately dies. From browsing on here sounds like the possibility of when the battery was replaced (2 weeks ago) could have knocked loose the air intake? Then it eventually came loose enough to cause this problem? Reason I ask is car is abandoned about 35 minutes away and don't want to incur a tow to a repair shop if it can be avoided... thoughts?
Old 02-06-2009, 01:56 PM
onair's Avatar
maybe your immobilizer
http://www.newbeetle.org/forums/showthread.php?t=33636
Old 02-06-2009, 03:43 PM
PinkBug4289's Avatar
St.Louis, MO, USA
Car: 2004 Turbo S
I have the same problem. I start it the engine turns over and then dies. It only does it sometimes and at random times. I find that if I start it and immediatly rev the engine in the high RPMs(with the car in park of course) that it will stay started.It may take a few repeating but then it works.
But whenever I take it in to get looked at it never does not start and the mechanic thinks I'm crazy...
Old 02-09-2009, 02:58 PM
vdubbugman53's Avatar
Arvada, CO, USA
does the immobilizer light flash on the dash? if not then that is not your issue? any check engine light? could be a bad cam or crankshaft position sensor
Old 02-12-2009, 11:45 AM
Default Final word
Turns out that when the battery was replaced the bolt on the clamp for the negative post was stripped. I had tried to tighten it as best as possible but evidently it wasn't secure. This caused an inconsistent connection for about two weeks, and that flipped out the computer. Needed to tow it to the dealer and they reset the computer (and replaced the battery connection).
Engine starts, then quickly dies I_love_orange Questions, Issues, Concerns, or Problems with the New Beetle 4 02-06-2009 12:09 PM
Beetle Starts and Dies kenwat 1.8 Liter Turbo 9 08-06-2008 10:41 PM
Car starts, sputters then dies instantly savethebluths.org 2.0 Liter Gas 11 03-15-2008 02:35 AM
Beetle starts then Dies!!!!! sunflower02 Questions, Issues, Concerns, or Problems with the New Beetle 1 09-09-2007 03:52 AM
Starts then stops faithola Questions, Issues, Concerns, or Problems with the New Beetle 2 04-05-2006 06:51 PM
